Mold In Unused Joint Compound - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-28-2013, 10:48 PM   #1
CitadelBlue's Avatar
Rewards Points: 97
Mold in unused joint compound
I keep a 1 gallon contained of joint compound to do touch up work now and then. I opened a container up in the spring and have used a little at a time over the summer. Had some touch up to do before I painted the kitchen and I've got speckles of mold on the mud in the container.
Any trade secrets on how to slow this down or prevent it in the future?
Ken
Because you NEVER have enough room .........
See my Trailer and Hitch Thread
CitadelBlue is online now   Reply With Quote
Old 09-29-2013, 06:26 AM   #2
Rewards Points: 12,828
Toss it, not worth trying to save it.
When using it open the top and put some in a mud pan and close the lid.
Do not wipe the knife on the side of the container. (It will dry and fall in at some point)
When your all done, use the knife to smooth the compound over the top of what's left in the container so there's less surface area exposed to the air. Then lay a layer of Saran Wrap over it to seal out air.
Do not try and scrap the mud pan and but it back in the original container.
Old 09-29-2013, 06:32 AM   #3
DIY staff
Rewards Points: 7,174
When that happens--chuck it---
Plastic wrap over the top of the mud might help--
Old 09-29-2013, 07:07 AM   #4
Rewards Points: 5,974
To keep it from happening again, when you ar done wipe the sides of the bucket, then add enough water to cover the mud then add a capful of bleach, and seal the bucket. The bleach will keep the mold from developing. The next time you use it jut pour the water off.
Old 09-29-2013, 07:24 AM   #5
Rewards Points: 97
hummm ... SaranWrape makes sense and so does the water and bleach. Will try that on the NEXT bucket ....
Ken
The Following User Says Thank You to CitadelBlue For This Useful Post:
oh'mike (09-29-2013)
Old 10-01-2013, 08:42 AM   #6
Rewards Points: 1,426
My train of thought is that you can scrape off the moldy parts and still use it, BUT I figure you may be spreading compound that will breed mold onto the walls. So like everyone else said, chuck it and buy some more. I had a bucket sitting around for two years that was fine a month ago when I opened it up and used a tiny amount. A couple of days ago the entire surface was green and furry.
mikegp is offline   Reply With Quote
Primer and Joint Compound Issues RIVO Painting 15 07-19-2013 11:47 AM
Sheetrock Brand "Dust Control" Joint Compound: A Review ScottieBaseball Building & Construction 3 08-26-2010 12:26 PM
Mold Resistant Joint Compound Red Truck Drywall & Plaster 0 02-27-2010 01:59 PM
Joint Compound shaggy0125 Painting 8 01-12-2010 03:55 AM
Joint compound over wood? flati General DIY Discussions 11 12-05-2009 08:59 PM
