Mold Resistant Drywall Or Greenboard? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-03-2013, 05:57 PM   #1
Rewards Points: 12
Mold Resistant Drywall or Greenboard?
Is the "Mold Resistant(retardent) Drywall sold at the big box stores the same or similar thing as "greenboard"? Which would you use in a bathroom?
natspawpaw is offline   Reply With Quote
Old 02-03-2013, 07:10 PM   #2
Rewards Points: 5,974
You can use either one they are basically the same.
Old 02-03-2013, 07:27 PM   #3
Rewards Points: 12,856
Just do not use it to lay tile over in the shower or tub area.
ToolSeeker (02-03-2013)
Old 02-04-2013, 07:37 PM   #4
Registered User
Rewards Points: 4,920
Two different beasts... Mold Resistant; 1/2" thick board, ceiling framing only at 16"o.c., never 24". 5/8" will go 24". with a water-based finish.
Green board, 1/2"; ceiling framing only at 12"o.c., need 5/8" for 16"o.c. 24"o.c.--- use another product. I'd use lightweight 1/2" spans (24"o.c.) equal to 5/8" for anti-sag, and insulation weight loaded above (2.2#).
http://www.usg.com/rc/data-submittal...tal-WB2390.pdf
http://nationalgypsum.com/products/..%5CFile%5C1046.pdf
Post #6; Drywall above shower?
Gary
Old 02-05-2013, 11:59 AM   #5
Mold!! Let's kill it!
Rewards Points: 2,012
Not all greenboard is mold resistant. Moisture resistance and mold resistance are two different things. Ask for a "cut sheet" where you buy it and read the specs. Mold resistant drywall is typically moisture resistant by nature, but not the other way around.
The Following User Says Thank You to Maintenance 6 For This Useful Post:
ToolSeeker (02-05-2013)
Old 02-05-2013, 10:51 PM   #6
Registered User
I've removed a lot of greenboard that looked like cottage cheese after some years...be wary of a vapor barrier/retarder in wet areas (or dry, IMO); http://publicecodes.cyberregs.com/ic...002_par013.htm
http://books.google.com/books?id=qhU...arrier&f=false
Gary
Old 02-06-2013, 09:14 AM   #7
It is my understanding they are doing away with the greenboard. I guess phasing out would be a better term. So what is out there now is just the remaining stock they are getting rid of.
The Following User Says Thank You to ToolSeeker For This Useful Post:
Gary in WA (02-07-2013)
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 09:15 PM
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 05:37 PM
drywall over old plaster... lcann25 Remodeling 0 09-21-2010 12:53 AM
Ecorock (new green drywall product) Sir MixAlot Drywall & Plaster 0 06-20-2009 09:40 AM
Would installing Moisture Resistant Drywall Backwards hurt anything? cdcamaro9534 Drywall & Plaster 6 11-01-2008 07:20 AM
