Mold Resistant Drywall? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-18-2011, 10:43 AM   #1
For our basement, should we consider spending a little extra for something like this?
We've only seen a few spots of moisture on the walls in one corner of the basement, and that has since been drylocked.
ctote is offline   Reply With Quote
Old 07-19-2011, 07:17 AM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
You are dealing with a space that's prone to high levels of moisture even if it appears dry. For the minimal amount of extra money it will cost, use the MR board. Use good building practices for below grade construction and the MR board will give you that much more peace of mind.
The Following User Says Thank You to Maintenance 6 For This Useful Post:
ctote (07-19-2011)
Old 07-19-2011, 11:41 AM   #3
Thanks for the tips! I've also read something about surrounding our staircase with fire rated drywall - know what I should look for when I go shopping? And, is there anywhere else I'll need to use fire rated drywall?
Old 07-20-2011, 07:48 AM   #4
US Gypsum makes a board called "Mold Tough VHI FIRECODE" that has both properties. You're not going to find it at the local home center, but a drywall supplier should have it or something similar. On a single family dwelling, I'm not sure there is a specific drywall requirement for stairways, not that it isn't a good idea. You'll want to finish it with mold resistant drywall compound, since the regular stuff has organics in it (mold food).
drywall over old plaster... lcann25 Remodeling 0 09-21-2010 12:53 AM
Mold in my brand new house ! dumbguy5689 General DIY Discussions 3 09-07-2010 02:26 AM
Mold around bathroom tub 99miles General DIY Discussions 1 08-15-2009 07:51 PM
mold resistance sheetrock drywall worth it stefjeano Drywall & Plaster 1 11-03-2008 07:57 AM
Would installing Moisture Resistant Drywall Backwards hurt anything? cdcamaro9534 Drywall & Plaster 6 11-01-2008 07:20 AM
