Mold Resistance Sheetrock Drywall Worth It - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-02-2008, 06:25 PM   #1
mold resistance sheetrock drywall worth it
I am making my basement a rec room. Should I use mold resistance sheetrock? There doesn't seem to be much moisture in there. It never gets wet.
stefjeano is offline   Reply With Quote
The Following User Says Thank You to stefjeano For This Useful Post:
headernae (09-04-2011)
Old 11-03-2008, 06:57 AM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
Just because it doesn't get "wet" doesn't mean that relative humidity levels aren't high. For the difference in cost, I use only fiberglass drywall in basements and bathrooms. It's too hard to tear out and replace later if you do have a problem.
Mold problem after unfinished house was closed in for the winter... lemonbltz Building & Construction 28 12-30-2011 07:52 PM
Mold on Green Drywall - how to remove? TotallyLostAlisha Drywall & Plaster 4 08-05-2008 06:47 AM
Applying Drywall Compound To Sheetrock shapeshifter Painting 9 04-29-2008 03:42 AM
Drywall, Mold Problem due to Leaked Water june03 Building & Construction 2 10-31-2006 07:24 AM
