Mold From New Joint Compound - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-22-2013, 10:05 PM   #1
Rewards Points: 248
Mold from New Joint Compound
Has anyone had an issue where they applied mud and a few days maybe a week later mold started to show?
I am redoing a bathroom in my basement and am at the point where I'm putting on the last coat of mud. after a week or so brown spots started to show up.
The first coat of mud(green lid) for setting the tape, there is no mold. And that's been sitting there for like 1 to 2 weeks before the finishing coats. I use the blue lid mud for easy sanding. Then is where the mud started to show.
Any ideas of how I can fix this without tearing down the drywall?
jburchill is offline   Reply With Quote
Old 10-22-2013, 11:06 PM   #2
Rewards Points: 13,300
Sounds more like a moisture issue then mold.
What's the humidly level in the basement?
Try a few dabs of bleach on it, if it's mold it should clear up in a few minutes.
Tell us more how this room was built from the foundation out to the sheetrock.
Old 10-23-2013, 12:30 PM   #3
Rewards Points: 248
Hello Joe, thanks for the reply,
Its been rainy here for October, so i'd say the humidity has been a little higher.
I did spray it with bleach and it didn't really change color.
The room is a remodel and it had drywall before. From the exterior wall its goes like this..exerior concrete wall, studs with insulation, vapor barrier, and then drywall. Has a concrete floor being in the basement.
Mold Resistant Joint Compound Red Truck Drywall & Plaster 0 02-27-2010 01:59 PM
Joint Compound shaggy0125 Painting 8 01-12-2010 03:55 AM
Joint compound over wood? flati General DIY Discussions 11 12-05-2009 08:59 PM
What To Prime Wood With to Accept Joint Compound? Lovegasoline Building & Construction 19 11-03-2009 06:04 AM
Hairline crack in joint compound elbee Building & Construction 10 12-02-2008 06:57 PM
