Mold On Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-22-2012, 01:17 AM   #1
mold on drywall
If Drywall Has Mold Should It Be Replaced Or Painted With Kilz
joeahd is offline   Reply With Quote
Old 01-22-2012, 02:54 AM   #2
mike owes me $53 dollars
Tech Dawg's Avatar
Why don't you give some more details about the job :whistling:
Todd
www.aloneeagle.com
Tech Dawg is offline   Reply With Quote
Old 01-22-2012, 03:15 AM   #3
Tech Dawg's Avatar
Shouldn'tPaintAgainstMold :whistling:
Todd
www.aloneeagle.com
Old 01-22-2012, 04:05 PM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
Drywall is cheap and easy to replace. Unless it is a very minor spot, then take it out. If it got wet enough to grow mold, it got wet enough to lose it's integrity anyhow.
Old 01-22-2012, 04:07 PM   #5
Rewards Points: 14,026
And what caused it mold up.
You have to figure that out first then fix it or it's just going to do it again.
Old 01-22-2012, 11:46 PM   #6
Rewards Points: 366
Sorry if I'm hijacking upon this thread, but I have same topic to ask. So thought maybe better to ask here as well rather than start another related thread.
If mold is only in a few spot areas, is it ok to remove that portion of drywall and then patch the hole, or better to remove & replace the entire drywall?
Also, if mold not too deep, could it be scrubbed off (the top layer and paint of drywall) with bleach & water, etc.? Then repaint.
Last question, what do you think looking at these photos? Is it mold, and does it look bad or just minor? The orange color on the drywall isn't really mold though right, just the black spots (on one photo) and dirty looking walls (on the other). Orange color = water stain / rust or something else?
http://dlshare.s3.amazonaws.com/temp/mold1.jpg
http://dlshare.s3.amazonaws.com/temp/mold2.jpg
http://dlshare.s3.amazonaws.com/temp/mold3.jpg
The affected drywall by touch feels ok, not soft and breaking apart, and not wet/moist, but yes still it doesn't look good. As you can see, this is obviously in the laundry room, the water supply pipes may have leaked sometime before. For the wall corner, I noticed the tenant drying clothes w/o turning on the vent fan, and one of the walls is faces the outside, so I assume those factor as causes for mold on the walls.
daluu is offline   Reply With Quote
Old 01-23-2012, 06:47 AM   #7
The first thing to do is scrub it all down with some detergent and get all the dirt off of it. From what I can see in the pictures, it doesn't really warrant a mold remediation effort. Just looks like maybe some mold growing on the accumulated dirt. After that, check the materials, drywall, woodwork and if they are sound, then apply some sealer and fresh paint.
Old 01-29-2012, 09:00 PM   #8
hummer4x4guy's Avatar
www.zymeaway.com for a natural plant based mold killer.
Joel
hummer4x4guy is offline   Reply With Quote
Mold on roof sheathing!!! DIYMILF Roofing/Siding 10 08-14-2011 09:11 PM
Mold in my brand new house ! dumbguy5689 General DIY Discussions 3 09-07-2010 01:26 AM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 09:42 PM
mold resistance sheetrock drywall worth it stefjeano Drywall & Plaster 1 11-03-2008 06:57 AM
