Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 01-20-2013, 12:47 PM   #1
Mold?
I had a small dark spot on wall in my back room, not thinking much of it while painting i painted right over after i was done i noticed it did not cover the spot and the spot bleed through, it is not as dark but still visible. Does anyone know if this is a sign of mold inside the wall???
Ckb3216 is offline   Reply With Quote
Old 01-20-2013, 02:37 PM   #2
Stuck in the 70's
Blondesense's Avatar
Mold?
There is no way to tell from the pic.
Are there any other indications this may be mold? Is it in a damp area? Bathroom, basement, humid area? Does the room smell musty at all? Old water leaks in the room?
If the answers are no, and that is the only spot I wouldn't sweat it.
Old 01-20-2013, 02:40 PM   #3
Mold?
No to all of your questions, thanks alot, was reading up doesnt seem to be. Thanks again.
Old 01-20-2013, 03:11 PM   #4
Mold?
Just looks like a stain, a sealing primer, let dry and paint agin.
ToolSeeker (01-20-2013)
Old 01-21-2013, 09:43 AM   #5
gravity always wins
Mold?
Doesn't look like any mold spot that I've seen and I've seen plenty. Cover it with a sealer/primer, then paint over it. Could be a spot of ink.
Old 01-21-2013, 10:03 AM   #6
Mold?
What's on the other side of that wall, is it an exterior wall, is there a window above.
If it is mold maybe you have an issue / water leak and painting will only cover it temporally.
laflsyl10 is offline   Reply With Quote
mold and asbestos pulper Flooring 2 09-02-2012 11:40 AM
How to - prevent basement mold crazymountain How To Guides 31 01-20-2012 08:59 PM
Mold on roof sheathing!!! DIYMILF Roofing 10 08-14-2011 10:11 PM
Mold found - unsure what to do?? izzyant88 General Discussion 12 06-17-2011 07:21 AM
Concrobium or White Vinegar? eis61374 Remodeling 8 11-17-2008 07:56 AM
