Is Moisture Resistant Sheetrock Required? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-23-2013, 04:36 PM   #1
Rewards Points: 29
Is moisture resistant sheetrock required?
Is moisture resistant sheetrock required in a kitchen? I was going to at least put it up around the stove and sink. But do the codes require it?
lmorsino is offline   Reply With Quote
Old 02-23-2013, 06:22 PM   #2
Rewards Points: 6,652
No, but nice to have along the wall where the sink is, going up at least 18" to 24" above the counter, if you do not plan on a tile backsplash.
If doing tile above the counter, I would just place it where the sink base is going.
Old 02-23-2013, 06:31 PM   #3
Rewards Points: 5,974
Check your local codes some areas say yes in all wet areas.
Old 02-24-2013, 07:16 PM   #4
Registered User
Rewards Points: 5,216
I agree to check with local AHJ, and there are restrictions when using it; http://publicecodes.cyberregs.com/ic..._25_par037.htm
http://publicecodes.cyberregs.com/ic..._25_par036.htm
Here is that GA-216 the code mentions; http://www.lafargenorthamerica.com/G...%20English.pdf
Gary
Moisture Barrier Behind AND on Top of Cement Board JasonCA Remodeling 0 04-07-2012 02:31 PM
High moisture in slab, should I put down a barrier for travertine? help! eezeekial Tiling, ceramics, marble 15 11-21-2011 06:14 PM
Basement Bathroom - Sheetrock - Moisture Issues. mikeynpz Building & Construction 2 05-24-2009 11:08 AM
Permanent Glass Top Picnic Table DangerMouse Building & Construction 17 04-24-2009 01:10 PM
Moisture meters and radiant concrete slab snowydaysrock Flooring 7 01-21-2009 07:33 AM
