Moisture Resistant Drywall And Mudding Drying Time - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-12-2013, 02:21 PM   #1
Rewards Points: 258
Moisture resistant drywall and mudding drying time
Hello, I am in the process of redoing my basement bathroom and I am using moisture resistant (purple and green) drywall. I was mudding the corners and noticed little dark specks. Then I noticed the mud wasn't completely dry. I mudded 3 or 4 days ago.
I didn't over mud either, I've been trying to do more layers with less mud, so I don't have to sand as much.
So, my question really is...does moisture resistant drywall cause the mud to dry slower?
Weird thing is, this is only on the purple drywall.
jburchill is offline   Reply With Quote
Old 10-12-2013, 04:53 PM   #2
Rewards Points: 14,294
More likely high humidly causing it to take longer.
Lower the humidity or add some heat to speed it up.
There should never be any specks in it. Dark specks would make me think mold already setting in.
Go buy a humidly gauge.
It should be no more then 45%.
If it is then you need a dehumidifier.
Old 10-12-2013, 05:09 PM   #3
Rewards Points: 258
I don't think its mold, i think its just wet still. Could very well just be a high humidity. I'll open a window in there and get some air flow.
The CELLAR gbwillner Project Showcase 112 02-17-2012 10:00 PM
drywall mud dry time before painting dmillar Painting 5 01-26-2012 12:52 PM
Drywall mudding mess amberngreg Painting 5 10-02-2011 01:15 PM
mudding on drywall kathyll Drywall & Plaster 1 07-06-2011 12:25 PM
Drywall Mudding Challenge: Seam vs. Tapered Corner cjakins Drywall & Plaster 3 03-10-2009 12:41 PM
