Moisture Resistant Drywall Code Question - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-08-2014, 10:57 AM   #1
A contractor is installing a new kitchen in our home, and the local building code references ASTM C 1396. My question is whether anyone knows whether this ASTM requires moisture resistant or moisture/mold resistant drywall behind a new backsplash. It seems based on a simple search around that a kitchen backsplash is a "limited exposure to moisture" area and therefore moisture resistant drywall is the way to go. Thanks in advance.
RicoJay13 is offline   Reply With Quote
Old 06-08-2014, 10:58 AM   #2
FYI we're planning subway ceramic tile backsplash if that matters.
Old 06-08-2014, 12:32 PM   #3
Rewards Points: 454
I would say you won't have a water issue if your going to put tile on it.
I no my county code just calls for green board around direct water like tubs in showers
scottktmrider is offline   Reply With Quote
Old 06-08-2014, 12:40 PM   #4
Rewards Points: 13,732
Just ask your local building dept. to be sure.
Different codes in different locations.
Old 06-08-2014, 04:38 PM   #5
Rewards Points: 5,974
Joe is correct check local as many locales are different. All I have dealt with the backsplash is not considered a "wet" area. The best solution would probably be Dura rock if just for piece of mind. Remember moisture can get through grout, but on a backsplash it's unlikely.
Old 07-11-2014, 12:26 PM   #6
Drywall contractor
Rewards Points: 1,070
Around here backsplashes are generally just put over the regular drywall. As stated above, it's not an area that gets a lot of direct water. Check local code though.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Existing Drywall Question AirborneB Drywall & Plaster 2 03-17-2013 03:25 PM
moisture resistant primer Startingover Painting 15 03-14-2013 04:31 AM
code question? yellowkid Building & Construction 8 03-03-2013 09:13 PM
Cleaning brush StevenH Painting 19 02-05-2011 11:13 PM
I have one code question which needs to verify. David200888 Electrical 0 12-21-2010 09:21 AM
