#1 |
moisture resistant on both sides of wall?
Newbie DIYer here. I'm putting an addition on our house to add a closet to a room. The other side of the new closet is a bathroom. I bought a few pieces of moisture resistant drywall but just learned about the problem using it on exterior walls along with vapor barrier insulation.
I'm closing off a window in that bathroom as part of the project. Can I use the moisture resistant stuff on both sides of the 2x4 studs or is that also a mold vulnerability? I now own 3 pieces of that stuff I don't need, so I'm hoping there's some way I can salvage some value. If not, I'll chalk it up to the cost of a DIY lesson learned. Thanks for any help. - Vivek. |
#2 |
Average Joe/ex-Navy IC3
No, do not use on the outside of the structure.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you? |
#3 |
Sorry wasn't clear. This is going to be an interior wall, bathroom on one side closet on the other. Is that still bad?
#4 |
i don't see a problem with that. as both sides should be about the same temp.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. i didn't make this world. i just live in it. be careful of whom you make fun of. one day, that could be you... |
| Display Modes | |
| Avoiding load on inner, exterior wall | jklingel | Building & Construction | 2 | 06-04-2011 02:35 PM |
| Building a half wall: 2 questions | kbizzle | Carpentry | 7 | 02-19-2011 09:22 AM |
| Running speaker wire from attic into exterior wall: Techniques? | homerb | Home Theater | 1 | 07-15-2010 02:55 PM |
| how important is it for moisture barrier to cover sides of floating floor? | conradA | Flooring | 2 | 04-29-2010 11:13 AM |
| Moisture Barrier for Partially Below Grade Grouted CMU Wall | Fire4Effect | Building & Construction | 4 | 07-06-2009 12:51 PM |
