Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 02-03-2013, 03:29 PM   #1
Moisture on exterior plaster wall
How do I stop condensation on a closet exterior plaster wall
redfish188 is offline   Reply With Quote
Old 02-03-2013, 03:39 PM   #2
Remove condinsation.
Going to need more info.
Let me guess, really old house.
Ballon wall constrution.
No idea on what, or if there's any insulation in in the walls.
Never been fire blocked in the basment between the walls or in the attic.
Wood siding attached directly to the studs with no vaper barrer or sheathing.
How much gap is there under the closit door?
What type roof venting do you have?
Soffit vents?
Old 02-03-2013, 03:52 PM   #3
Super Moderator
Joe is onto something---the wall is cold----so getting it up to the insulation level of the rest of the room is the best start--
Then getting some air circulation or more heat in the closet will help.
Is this a regular yearly problem or has this just started to happen?
How to Square a Wall or Layout for a Foundation BigJim How To Guides 2 01-31-2013 10:48 PM
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 07:23 PM
Removing spine wall beko Building & Construction 12 02-02-2010 02:15 AM
Moisture Barrier for Partially Below Grade Grouted CMU Wall Fire4Effect Building & Construction 4 07-06-2009 12:51 PM
