Moisture Barrier Board - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-05-2013, 05:59 PM   #1
Rewards Points: 31
moisture barrier board
Is blue board easily available and is blue board close to green board with regards to moisture barrier. And how much of a different in cost if any?
jbillups is offline   Reply With Quote
Old 03-05-2013, 07:01 PM   #2
Rewards Points: 13,250
Both the same thing just differant companys made it.
Any box store, drywall supply, lumber yard will have it.
Old 03-05-2013, 07:59 PM   #3
Registered User
Rewards Points: 5,204
Just check the install directions as some require 12" or 16" on center framing spacing; http://publicecodes.cyberregs.com/ic...002_par013.htm
http://publicecodes.cyberregs.com/ic...002_par014.htm
Gary
Old 03-06-2013, 11:22 AM   #4
Rewards Points: 5,974
Are you sure it's the same thing? Blue board is for plaster, green board(whice they doing away with) is for compound. I really don't know if this would make a difference or not. Just asking.
And to poster I don't think either is considered a moisture barrier.
Old 03-06-2013, 04:48 PM   #5
Mold!! Let's kill it!
Rewards Points: 2,012
Agreed. Blue board is a base for veneer plaster and doesn't even have depressed edges like drywall. The facer is not meant to provide a finished surface. Greenboard is moisture resistant drywall, but is meant to provide a finished surface ready to paint. Newer purple colored board (MR board) is moisture and mold resistant. None of these are moisture "barriers". None will survive any extended exposure to water.
The Following User Says Thank You to Maintenance 6 For This Useful Post:
ToolSeeker (03-07-2013)
"Green" hardwood flooring underlayment and moisture barrier question Kate24 Flooring 16 02-27-2012 06:24 PM
What type of moisture barrier is needed for solid hardwood naildown flooring? htabbas Flooring 10 11-30-2011 08:51 AM
High moisture in slab, should I put down a barrier for travertine? help! eezeekial Tiling, ceramics, marble 15 11-21-2011 06:14 PM
Basement floor finishing: Moisture Barrier? junior.carls Flooring 2 08-31-2011 11:51 PM
Moisture Barrier and Adhesive Removal joe_cole5000 Flooring 5 01-31-2010 04:06 PM
