Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 10-09-2009, 01:13 PM   #1
dIYHell
mixing tile and drywall
I Have a fireplace mantel that I am just installing drywall and putting a plaster like coating called american clay). This coating is not more than a 1/16 inch thick. My wife (always making my life difficult) wants to have a strip of tile run horizontally along this mantel. The tile is a quarter inch thick.
how would I do this so the tile looks to be at the same level as the plaster. I am thinking I would use 5/8 and 1/2" drywall to build the different thickness to inset the tile. I would imagine I would need to tape these drywall together as well?
rocketdoctor is offline   Reply With Quote
Old 10-09-2009, 01:17 PM   #2
sdsester's Avatar
The difference between 1/2" and 5/8" will only give you 1/8" difference which will leave the tile 1/16" higher. Will this work for you? What are you using to back the tile?
Otherwise I would fir out the studs I guess.
sdsester is offline   Reply With Quote
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Improving a bad tile to drywall transition navi_jen Drywall & Plaster 5 10-12-2009 09:32 AM
Replacing drywall without removing tile through an interior wall MLP Drywall & Plaster 6 08-06-2009 12:35 PM
Larger ceramic tile on drywall? HABSFAN2006 Drywall & Plaster 8 05-29-2009 04:24 PM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 04:00 PM
