Metal Corner Bead Vs Paper-Faced Bead - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-20-2011, 09:39 AM   #1
Veteran Rehabber
Question
Metal corner bead vs Paper-Faced bead
I am always looking for new products and ideas that will improve the quality of my work or take less time. Paper-Faced Metal Corner Bead seems to do both. According to one manufacturer who offers a 30-year warranty, "Paper-faced bead products eliminate corner cracking commonly experienced when traditional metal bead is used. Metal bead is fastened to a structure’s wood framing. When the framing shrinks, warps or swells, the bead moves with it and can cause corner cracks. Unlike metal bead, Paper-faced bead is attached to the drywall, not the framing. Consequently, there is less stress from minor structural movement placed on the bead, and thus, no cracking. It installs 30 to 40% faster because no nailing is required and less mud work is needed."
Am I missing something here? Does anyone who has used it have an opinion?
CMHbob
Visit my blog for latest project and reno tips!
CMHbob is offline   Reply With Quote
Old 04-20-2011, 10:07 AM   #2
Not so new
12penny's Avatar
Rewards Points: 520
CMH...I only use paper face for corners other than 90*.
12penny is offline   Reply With Quote
Old 04-20-2011, 10:15 AM   #3
they make a crimp tool for metal, uses no nails
The older I get the better I was
Old 04-24-2011, 12:21 PM   #4
Wow...
I wonder were you guys are? Here we've been using "paper" faced bead for 30 years. Metal nail on / Crimp on bead is inferior by far! The reasons are just numerous.
Paper bead uses less mud and most importantly it is laminated to the drywall. This has so many benefits I honestly can't believe anyone would ever choose to buy metal bead.
Metal bead when it is crimped on eventually will form hairline cracks, if not actually pop right off when bumped.
Metal bead which is nailed/screwed on will twist when the stud it is attached to dries out and twists, this results in cracks.
Metal bead, because it is so deep, because it uses so much mud, is always prone to shrinkage over time, resulting in a hollow look.
Paper bead, it's superior in every aspect. It uses less material, it doesn't shrink and most importantly it's very hard to "crack" when it's applied properly. It takes a lot of brute force to pop/crack a properly installed paper faced corner bead.
I would never ever buy metal cornerbead and if I did ever use it, i would crimp or glue it on and then I woud tape it on both sides thus in effect turning it into a paper faced bead.
~ A Professional Drywall Finisher
dberladyn is offline   Reply With Quote
The Following User Says Thank You to dberladyn For This Useful Post:
CMHbob (04-24-2011)
Old 04-24-2011, 04:36 PM   #5
Drywall contractor
Rewards Points: 1,070
Using a crimp on tool doesn't fasten as securely as nailing, bead is more easily knocked loose or off. The crimp tool will help get the bead on square, but nails should be used too. The paper faced metal bead is applied with mud and won't pop and twist as stated. It's what I use and have not had any issues.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 04-07-2017, 05:06 PM   #6
cocobolo's Avatar
Rewards Points: 5,952
Re: Metal corner bead vs Paper-Faced bead
Gentlemen: I realize this thread is very old, but it was the first thing that came up when I searched for paper bead vs. metal bead.
I'm not a drywaller by any stretch of the imagination, but I cannot seem to get the paper bead to go on without the occasional bubble showing up once the mud dries...first coat of course.
What am I doing wrong?
Your help will be much appreciated.
Thank you in advance.
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 04-09-2017, 07:39 PM   #7
I like to use the plastic trim Tex bead, you can put it on with spray adhesive or Staples or both
ktmrider is offline   Reply With Quote
Tags
corner bead , drywall , paper-faced
Rusty Corner Bead - What To Do? WoodySoCo Painting 9 04-10-2011 06:35 PM
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 10:16 PM
How to Install paper edge corner bead - AtlanticWBConst orange Building & Construction 7 10-23-2008 12:34 PM
drywall corner bead drewhart Drywall & Plaster 2 10-22-2008 09:28 AM
Flexible metal corner bead? Worth using? yummy mummy Building & Construction 3 11-15-2007 06:09 PM
