Metal Corner Bead Separating From Wall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-29-2012, 08:08 PM   #1
Metal corner bead separating from wall
Is this a sign of something significant wrong with the structure or just a usual home repair? We are looking at a condo and on the visit we noticed that in several places around condo the metal corner beading is pulling away from one wall or the other. The condo is about 30 years old. My house is 20 years older but does not show the same condition.
david0120 is offline   Reply With Quote
Old 07-29-2012, 08:31 PM   #2
Rewards Points: 558
Without a picture Iím assuming your problem is shrinkage. To fix this problem you can nail the corner bead every 4 inches and avoid flattening the corner bead when fastening the nails. Then cover with drywall mud, sand, prime and paint.
epson is offline   Reply With Quote
Old 07-29-2012, 08:32 PM   #3
DIY staff
Rewards Points: 7,174
That is a sign if a poorly set metal corner bead---nothing uncommon--just a sloppy drywall guy---
Old 08-01-2012, 11:26 PM   #4
Registered User
Rewards Points: 5,216
Many times I find lifting metal corner beads. Usually if one side is lifting, it is on the wide side of the stud vs. the narrow edge of that stud. Lumber expands/contracts more on the wider face than on its edge, working the fasteners loose or creating stress there. http://www.paintsource.net/pages/sol...ood_shrink.htm
Around here on older houses (before DIY was popular due to internet), the metal c.b. was applied by pros (and as Mike said- not all pros) with adequate fastening, the seasonal (or indoor by HVAC) changes in humidity can disrupt the finish. Fasteners into the framing at the corners is the problem, use a paper faced metal corner bead that won’t have the movement as it is fastened to the drywall only, not the wood framing. This should change your odds that any corner crack/separation won’t happen again. The older c.b. has a 3/16” hole every 4” for joint compound to help adhere it to the drywall, the newer ones have holes twice that size and closer spacing (someone learned). http://www.homedepot.com/webapp/cata...gry=SEARCH+ALL
If you refasten, don’t use the bigger (mud) holes: http://literature.usg.com/pdf/J1445.pdf
Fig.5, and read “Corner bead” pp.5 and 6: http://bestdrywall.com/files/ReduceCallbacks.pdf
This will help you blend, be sure to prime before finish paint: http://www.youtube.com/watch?v=4WdMo...eature=related
Gary
P.S. welcome to the forums!
Old 08-02-2012, 12:28 AM   #5
This is probably not a real bad problem. It can be fixed easily, some say put nails in, but I say put a little mesh over top the crack, and coat it with some mud before repainting. This will fix the crack and it shoud not come back, many great tips can be found on
Last edited by Gary in WA; 08-02-2012 at 01:03 AM. Reason: removed advertising link as per forum rules.
bluntman001 is offline   Reply With Quote
Old 08-02-2012, 01:05 AM   #6
Registered User
Mesh tape will show movement faster than paper tape. I would not recommend it for this application.
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
chrisn (08-02-2012)
Old 08-03-2012, 02:17 PM   #7
Rewards Points: 454
Just take the old bead off and put new up, make sure you nail and tape it.I have seen alot of amature tapers not tape the bead thats one reason it cracks.
scottktmrider is offline   Reply With Quote
Old 08-03-2012, 10:52 PM   #8
all the corner bead i removed around the window and door openings in my house was nailed every 18 inches and was loose. it's the only real bad workmanship i have found in the whole house. i could measure and find the nails they were so consistant. its faster to use less nails.
Mounting Corner Wall Mount Sink petedickson82 Plumbing 2 02-17-2010 10:28 PM
Corner Bead for Double Drywall? whipper Drywall & Plaster 11 08-12-2009 02:19 PM
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 11:16 PM
attaching corner bead to metal studs ar2736 Building & Construction 2 10-28-2008 12:32 PM
Replacing a corner post, Reinforcing the wall? jlawrence42 Building & Construction 5 08-21-2006 12:41 PM
