Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 04-10-2011, 11:03 PM   #1
MikeKy55's Avatar
Metal corner bead on 20' soffitt
Did a search and didn't find anything on this topic. I'm finishing my basement and have soffits enclosing the duct work and main beams. Now that the rock is hung, I need to put metal corner bead up. Is there a better way of joining pieces rather than simply attaching one and then the next taking care to get them aligned?
MikeKy55 is offline   Reply With Quote
Old 04-11-2011, 08:43 AM   #2
Old School
Willie T's Avatar
Nope, you hit it. Butt the factory ends together carefully... do not try to overlap them.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
MikeKy55 (04-11-2011)
Old 04-11-2011, 08:54 AM   #3
Not so new
12penny's Avatar
...thats what I'd do as well, although a roll of paper faced corner bead would be a good option as well. No seams, but you might need someone to help out.
12penny is offline   Reply With Quote
The Following User Says Thank You to 12penny For This Useful Post:
Old 04-12-2011, 12:37 AM   #4
firehawkmph's Avatar
I use a clincher tool to seat the bead then follow up with ringshank drywall nails. Lining up the ends really isn't a problem if you are carefull at all.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 04-12-2011, 07:18 PM   #5
MikeKy55's Avatar
Thanks guys. Yeah they line up pretty easy. Just took the time to center the screws in the holes so they didn't pull the bead one way or the other.
Bullnose Corner bead question ryan5068 Drywall & Plaster 11 03-13-2011 08:43 PM
Ceiling corner bead kchopper Drywall & Plaster 8 03-18-2010 11:36 AM
drywall arch corner bead rustic Drywall & Plaster 16 10-27-2009 05:58 PM
corner bead for drywall cfarmer Drywall & Plaster 2 04-13-2009 04:20 PM
drywall corner bead drewhart Drywall & Plaster 2 10-22-2008 10:28 AM
