Medium Sized Holes In Wall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-27-2014, 11:22 AM   #1
Exclamation
Medium sized Holes in wall
I've never repaired a wall before so any help at all is encouraged.
(pictures below)
Snakey is offline   Reply With Quote
Old 08-27-2014, 11:22 AM   #2
Old 08-27-2014, 11:24 AM   #3
Old 08-27-2014, 12:53 PM   #4
Rewards Points: 454
Use a hot patch or also called a California patch
scottktmrider is offline   Reply With Quote
Old 08-28-2014, 06:57 AM   #5
Rewards Points: 5,974
Those are too big for a hot patch they need a couple blocks behind them.
Old 08-28-2014, 08:00 PM   #6
Rewards Points: 4,780
For a DIYer, I'd just buy one of these and be done with it. Assuming nothing will be fastened to that wall location in the future....
http://www.homedepot.com/p/Wal-Board...-006/100036128
jeffnc is offline   Reply With Quote
Old 08-29-2014, 06:58 AM   #7
Yea they come in up to 8"x8".
Old 09-12-2014, 10:20 PM   #8
Jello Wrangler
Rewards Points: 539
ToolSeeker is on the right path. A couple of blocks and some drywall is the way to go. Those mesh metal patches are junk and are not that easy to blend. You could hybrid the patch and do a cali with some backing. The cali patch will allow you to reduce the thickness of the repair and give you back the integrity of the structure.
ChiTownPro is offline   Reply With Quote
Old 09-12-2014, 10:30 PM   #9
Rewards Points: 121
Take a look at this quick tutorial. Only change I would make is buy a small bucket of lightweight joint compound and use that instead of worrying about mixing your own.
mikeyp78 is offline   Reply With Quote
Old 09-12-2014, 11:39 PM   #10
In increasing order of quality and strength and use of the wall, and decreasing order of convenience and ease of fix. Given that you've never done it before, take your pick based on your confidence level.
- self adhesive metal patch
- california patch
- full blocker support with furring strips
- same as above but with setting compound (mix yourself) instead of drying compound (premixed)
The last one is the strongest, but you don't necessarily need it. I do it anyway so I can finish the whole patch in an hour, instead of waiting 3 days for 3 coats to dry. In your own home, that shouldn't be a problem since you don't have to make 3 trips to the job site.
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 01:26 PM
Core filling a bowing wall, please assist silverstrike Building & Construction 12 06-16-2012 11:28 PM
Avoiding load on inner, exterior wall jklingel Building & Construction 2 06-04-2011 02:35 PM
patching holes in basement cement block wall jhiner Building & Construction 3 06-02-2010 04:03 PM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
