maximum gap between panels
Originally Posted by amakarevic
i mean, mud is mud, i didn't know it could be made hot.
i understand that any gap should be filled with mud. my question was how much of a gap is "mudable" before you decide that not even mud could fix it and you should just put a new panel to make a closer gap.
I'd say 1/4" maximum gap.
Hot mud= powder setting type compound/mud that needs to be mixed with water. Much stronger then premix bucket mud.
Checkout some of To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
