Maximum Ceiling Joist Spacing - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-20-2012, 06:13 PM   #1
Rewards Points: 1,062
Question
maximum ceiling joist spacing
if i am using 5/8" drywall, what is the maximum spacing recommended for ceiling joists?
i know that it is up to 24" between stud centers for vertical studs but i am not sure if the same applies for the ceiling because there is more gravity force involved pulling it down, hence more dense fastening should be needed, even on top of thicker sheets.
Old 03-20-2012, 06:22 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
http://www.usg.com/rc/installation-a...de-en-J371.pdf
- Build Well -
The Following User Says Thank You to AtlanticWBConst. For This Useful Post:
amakarevic (03-20-2012)
Old 03-20-2012, 06:32 PM   #3
thanks. looks i'm good all the way up to 24" considering that i am going perpendicular sheet to joist (why go any other way?)
Old 03-20-2012, 06:41 PM   #4
Ravenworks's Avatar
I always double screw and glue,read up about where you should float you joints,I learned that the hard way.
Ravenworks is offline   Reply With Quote
Old 03-25-2012, 11:47 AM   #5
Drywall contractor
Rewards Points: 1,070
The new 1/2" lightweight board (at least USG Ultra Light) is rated for 24" centers even with water based texture applied. Much easier to handle than 5/8" if you don't HAVE to use it for fire code reasons...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
The Following User Says Thank You to bjbatlanta For This Useful Post:
amakarevic (03-25-2012)
Adding wall with door opening - sloped ceiling and no joist for top plate Jebross Remodeling 11 01-11-2012 10:34 AM
Opening Ceiling Joist for Recessed Light DAKRO Building & Construction 14 01-01-2012 01:21 AM
Incremental benefit of insulating rafters in addition to ceiling joist bays? benjamincall Insulation 13 12-26-2011 02:17 PM
ceiling joist size - 2x4 or 2x6 needed? bigdaddy352 Building & Construction 9 08-21-2007 01:02 AM
