Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 10-08-2010, 05:27 PM   #1
Mating drywall to plaster on an inside corner
Hey Guys,
Quick question/advice request:
I am installing some drywall that is butting up to old plaster in a corner. The plaster the drywall is replacing was about 1" thick, using 1/2" drywall.
My plan is to scrape the area were the old plaster met up, then mount the drywall butted up to the plaster like shown, then use some hot mud to smooth out the 1/2" strip still exposed where the old plaster was and fill in any areas where there are gaps (drywall is a little jagged). Then just tape up the corner like normal.
Sound good or should I do it some other way. Never done drywall to plaster in a corner like this.
Thanks in advance.
acme54321 is offline   Reply With Quote
Old 10-09-2010, 01:04 AM   #2
Phoenix
We don't get to see much real plaster here in Phoenix, but ... I would do it just like you are.
Axecutioner-B is offline   Reply With Quote
Old 10-09-2010, 06:04 PM   #3
While a larger waste of material, would it not be easier to double the drywall up to the 1" thickness, or at least shim the wall 1/2" behind the drywall?
Food for thought.
n0c7 is offline   Reply With Quote
Old 10-12-2010, 08:49 AM   #4
Food for thought.
I thought about that, but I think it would be just as easy to use some mud to fill any voids and smooth out the edge. I am going to tape over that area anyway so it doesn't have to look good or anything.
Old 10-14-2010, 12:09 AM   #5
Gonna be tricky to smooth out but doable.
drywall mixed with plaster - do I need to tape? Windows Drywall & Plaster 4 03-09-2010 04:02 PM
Corner Bead for Double Drywall? whipper Drywall & Plaster 11 08-12-2009 02:19 PM
Drywall over plaster? Rob1980 Drywall & Plaster 10 04-11-2009 06:05 PM
filling gap in drywall corner listo Drywall & Plaster 6 01-27-2009 09:29 PM
Plaster Ceiling and drywall dprasan Remodeling 6 02-06-2008 12:34 AM
