Matching New With Old - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-28-2010, 12:36 PM   #1
Matching new with old
I tried over on the paint side and haven't gotten any responses so I figured I would try here too.
We are doing some renovation work and there are a number of places where new drywall now joins existing walls or ceilings (a mix of painted plaster and drywall). The new drywall and mud were sealed with Zinnser Guardz and then primed with 123 but the textures of the new are not a particularly good match for the existing. Existing walls are not really textured in the popcorn hide a mess sense of the word, but they definitely not as smooth and are little more orange peely than the new work. I'm looking for ideas to blend things better. I've been using a 3/8" roller but I'm thinking something a little longer might make the patches and new work less obvious. I'm hoping to avoid high build primer and sanding everything. Suggestions would be welcome. Thanks!
Geodude is offline   Reply With Quote
Old 09-28-2010, 07:33 PM   #2
I think you need a longer nap on your roller to give a better textured look, I once saw a texture roller at HD, never used one but it might be worth a try, also if your wall texture looks like orange peel they make a spray can mix you can try but you may have too much area to cover, I have tried the spray can popcorn for a small repair job that turned out really well. I would opt for a different roller......
are you using paint? you might consider mixing in a small amount of drywall mud which will help with that textured look...
newfie49 is offline   Reply With Quote
Old 09-30-2010, 12:23 PM   #3
Matching it will be a *****. So is sanding. Grab a 12 inch knife and scrape the wall. After you've scrapped the wall you will have a somewhat uniform depth. Now spray texture the wall. Should turn out fine.
unlvrebel is offline   Reply With Quote
Color Matching with Aura & BM Classic Colors mobiledynamics Painting 1 09-20-2010 02:18 PM
Tips for matching the texture of plaster? Ptron Painting 3 09-15-2010 02:59 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
matching paint comes out gray mmsuki Painting 6 09-03-2009 09:31 AM
matching kitchen cabinets ponch37300 Remodeling 4 02-08-2009 09:41 PM
