Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 01-28-2013, 07:27 PM   #1
Match plaster texture
I have to fix a spot in my plaster wall, but don't have any idea on matching texture. I can't tell if its just lots of coats of paint on the wall or a specific texture. Here is a picture of a painted wall and then a spot of just plaster never painted. We removed something from the wall and now I have to get it to match.
Match plaster texture-image-2328467701.jpg   Match plaster texture-image-285334173.jpg
bryanp22 is offline   Reply With Quote
Old 01-28-2013, 08:33 PM   #2
I just had to do something similar and it's a challenge to match a texture perfectly.
But to my DIY eyes it looks like a form of orange peel texture.
You could use some joint compound to build up the recessed area you have there, let it dry, sand and blend in the edges, doing 2 or 3 coats of the dry wall compound.
They sell cans of orange peel texture that you can spray on, make sure to do a few tests on old scrap wood or wallboard so you can make sure you get the size right.
This is the stuff I used:
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?productId=100586541&storeId=10051&l angId=-1&catalogId=10053&ci_sku=100586541&ci_kw={keyword} &kwd={keyword}&cm_mmc=shopping-_-googleads-_-pla-_-100586541&ci_gpa=pla#.UQcmFM-oCUA
Up close you can see a slight difference but from a far and at a quick glance it seems to do the job.
tjansen is offline   Reply With Quote
Old 02-02-2013, 01:50 PM   #3
I agree, go to Lowes or HD and buy a can of spray for splatter or knockdown and test first then apply to area in short spurts, that should be close.
"don't bend over in the garden, granny, them taters got eyes"
newfie49 is offline   Reply With Quote
Old 02-02-2013, 01:58 PM   #4
I picked up a can and it does match pretty good. It's a little bit of a skill not putting it on heavy, but I think I got it.
Old 02-02-2013, 04:37 PM   #5
Moderator
Alternative; http://www.youtube.com/watch?v=4WdMo...eature=related
Gary
Clothes taking longer to dry?
trying to match interior plaster over brick ironnickwhite Drywall & Plaster 2 11-14-2012 08:38 PM
Tips for matching the texture of plaster? Ptron Painting 3 09-15-2010 03:59 PM
Venetian Plaster FYI Plaster Ayn Painting 10 07-01-2010 12:26 AM
Can you texture plaster walls? destes50 Painting 5 11-06-2009 10:51 AM
Texture to plaster bofusmosby Remodeling 2 05-05-2008 08:33 AM
