-   -   Match plaster texture (http://www.diychatroom.com/f101/match-plaster-texture-170414/)
bryanp22 01-28-2013 07:27 PM
2 Attachment(s)
I have to fix a spot in my plaster wall, but don't have any idea on matching texture. I can't tell if its just lots of coats of paint on the wall or a specific texture. Here is a picture of a painted wall and then a spot of just plaster never painted. We removed something from the wall and now I have to get it to match.
tjansen 01-28-2013 08:33 PM
I just had to do something similar and it's a challenge to match a texture perfectly.
But to my DIY eyes it looks like a form of orange peel texture.
You could use some joint compound to build up the recessed area you have there, let it dry, sand and blend in the edges, doing 2 or 3 coats of the dry wall compound.
They sell cans of orange peel texture that you can spray on, make sure to do a few tests on old scrap wood or wallboard so you can make sure you get the size right.
This is the stuff I used:
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?productId=100586541&storeId=10051&l angId=-1&catalogId=10053&ci_sku=100586541&ci_kw={keyword} &kwd={keyword}&cm_mmc=shopping-_-googleads-_-pla-_-100586541&ci_gpa=pla#.UQcmFM-oCUA
Up close you can see a slight difference but from a far and at a quick glance it seems to do the job.
newfie49 02-02-2013 01:50 PM
I agree, go to Lowes or HD and buy a can of spray for splatter or knockdown and test first then apply to area in short spurts, that should be close.
bryanp22 02-02-2013 01:58 PM
I picked up a can and it does match pretty good. It's a little bit of a skill not putting it on heavy, but I think I got it.
Gary in WA 02-02-2013 04:37 PM
Alternative; http://www.youtube.com/watch?v=4WdMo...eature=related
Gary
