Mastic On Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-05-2013, 11:29 AM   #1
Question
mastic on drywall
I want to do a pebble backsplash trim on top of existing backsplash (granite) on my bathroom vanities. What so I need to do to the drywall before using the mastic? Do I need to seal it? It has been painted and the home is new, so there is no foreign matter on the walls.
Marcy McPike is offline   Reply With Quote
Old 07-05-2013, 12:23 PM   #2
Rewards Points: 13,712
100% sure you really want to do that?
Going to be near impossible to clean.
Old 07-05-2013, 02:40 PM   #3
Yup!
I have done it before. Maybe I didn't describe my intentions well: the pebbles/stones will go ABOVE the granite backsplash, about 4" high, directly on the drywall and will serve no other purpose than a decoration. I will grout around the stones as well. My concern was more about whether or not the moisture from the mastic will penetrate the drywall and cause problems. Last time I did this application I really did not consider the moisture in the mastic damaging the drywall. Thus, my quandary. I did this in a spa in my last house. Over the 7 years I lived there I did't see any problems, but the spa was not used very often.
Old 07-05-2013, 03:02 PM   #4
DIY staff
Rewards Points: 7,174
Tiling over painted drywall is fine---simply scuff sand the paint,lightly before proceeding.
You will be okay with mastic if the border is in a dry area--I prefer thinset as it sets faster and bonds better--
-you might investigate using a modified grout to set the pebbles,using the color you wish to grout the finished work---Youtube
has an excellent video showing that--(I lost the book mark,sorry) I have used that technique with stone mosaics with good success.
ToolSeeker (07-05-2013)
Old 07-05-2013, 04:16 PM   #5
Thank you!
I appreciate your input! I will go ahead with the mastic as planned. I will also check out the modified grout idea!
Old 07-05-2013, 04:51 PM   #6
DIY staff
That worked well with the picky little mosaics----
Old 07-06-2013, 12:51 AM   #7
Rewards Points: 4,796
Technically moisture will probably penetrate to the drywall through the paint, but it doesn't matter. Think of how much moisture penetrates the drywall when it's first installed - when joint compound is applied 3 times to bare drywall. Or think about how much moisture there is when paint is applied to bare drywall.
jeffnc is offline   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
Marcy McPike (07-06-2013)
Old 07-07-2013, 07:34 PM   #8
Rewards Points: 5,974
You will no water in your drywall. First this is not like a shower it's a backsplash any water that hits it will be small amounts. Second that small amount of water will not go thru the tile then the mastic then the paint.
The Following User Says Thank You to ToolSeeker For This Useful Post:
Marcy McPike (07-07-2013)
Drywall question. DerWookie Drywall & Plaster 11 11-08-2011 07:08 AM
Drywall Dust Question izzyant88 Building & Construction 2 10-28-2011 09:32 PM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 08:15 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
