Making Butt Boards - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-21-2014, 01:52 AM   #1
Rewards Points: 422
Making Butt Boards
I need to make a few butt boards, but I have read about different sizes. Some say 6" wide, some say 7" wide, and some 9" wide. I also read 47" long, and 48" long. What do you guys suggest? Thanks.
Jim McC is offline   Reply With Quote
Old 01-21-2014, 07:10 AM   #2
Rewards Points: 5,974
The ones I bought are 6" x 47".
Old 01-21-2014, 12:56 PM   #3
Rewards Points: 422
Thanks. Do you guys think there's any benefit in going wider than 6"? I need to make these today.
Old 01-21-2014, 01:08 PM   #4
Here's something from FHB, if case you haven't seen it yet.
http://www.finehomebuilding.com/how-...tt-joints.aspx
northernlite is offline   Reply With Quote
Old 01-21-2014, 03:07 PM   #5
47_47's Avatar
Rewards Points: 44
If cutting with a circular saw (1/16" kerf) would make them either 5-15/16" or 6-3/8" wide to maximize a 4' x 8' sheet. Any width between about 6" and 7" will work. They are just used to give a slight recess to the seams.
47_47 is offline   Reply With Quote
Old 01-22-2014, 01:17 AM   #6
Rewards Points: 422
Thanks guys. I wound up making them 9" wide, like the above link.
Metal framing, magnesium oxide (MgO) boards Quinian Building & Construction 2 02-03-2011 04:57 PM
old wet barn boards LINUS Introductions 4 11-11-2009 07:08 AM
Composite Deck Boards dgoodwin3364 Carpentry 10 06-05-2009 12:09 PM
Diagonal boards over joists - rip up? vetting Flooring 17 02-03-2009 07:57 AM
Cutting attic floor boards Ultrarunner2017 Electrical 9 01-10-2009 11:45 AM
