Luan Plywood To Patch Plaster Wall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-27-2013, 09:13 PM   #1
Rewards Points: 208
Luan Plywood to Patch Plaster Wall
My first floor laundry/utility room will have a 4' high hole because of plumbing work (below is crawl space). The plumber said he could patch the plaster wall with luan plywood. The laundry room doesn't look that great so I'm fine with it. Do you guys see any problems with patching plaster wall with luan plywood? Like insects coming through the edges of plywood?
Scully is offline   Reply With Quote
Old 06-27-2013, 09:20 PM   #2
Old School
Willie T's Avatar
You're kidding, right?
Willie T
Old 06-27-2013, 09:39 PM   #3
Rewards Points: 208
unfortunately, no...why?
Old 06-28-2013, 05:14 AM   #4
DIY staff
Rewards Points: 7,174
Luan p;y falls apart when it get damp==in short order it will be a mess.
Either patch with drywall or use a better grade of ply.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
Scully (06-28-2013), user1007 (06-28-2013)
Old 06-28-2013, 06:08 AM   #5
Rewards Points: 208
mike, what type of plywood? will they nail it to the studs?
Old 06-28-2013, 04:59 PM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 298
If whom ever is doing the work was going to use luan , then you need to find someone that knows what the heck they are doing
The Following User Says Thank You to chrisn For This Useful Post:
Old 06-28-2013, 05:05 PM   #7
Too Short? Cut it Again!
Plaster is best repaired with plaster from my experience. You will need structure behind the repairs but luan is not the material of choice.
Old 06-28-2013, 06:38 PM   #8
DIY staff
What you want to see is 'exposure 1' or exterior glue--
BC plywood is usually exposure 1----The letters stand for the face grades--A is smooth sanded--B is smooth with some patches--c has tight knots--D had void and open knots
user1007 (06-29-2013)
Painting exterior plywood wall sheathing hiphi45 Building & Construction 2 12-24-2011 12:12 PM
Bathroom Remo: Is this Plaster over Concrete Block? Mounting Backerboard over top? itcanadian Remodeling 10 03-21-2011 12:06 PM
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 06:23 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 04:48 PM
Lath & Plaster Wall Box winesmile Building & Construction 2 12-03-2008 01:58 PM
