Low Dust Drywall Mud Won't Dry? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-31-2012, 09:14 AM   #1
Rewards Points: 97
Low dust drywall mud Won't dry?
I bought some low dust compound. I layed it on and let it dry 24 hours. It looks like it shrinks and cracks. I push on it and I can be pushed like soft clay.
What do I do? Just let it sit some more? Looks like this stuff won't harden.
edta1 is offline   Reply With Quote
Old 12-31-2012, 09:48 AM   #2
What's the temperature and how thick did you apply it? If area is damp or cool it will take much longer to set up and dry, also if its cracking? you may have put it on too thick.....??
"don't bend over in the garden, granny, them taters got eyes"
newfie49 is offline   Reply With Quote
The Following User Says Thank You to newfie49 For This Useful Post:
ToolSeeker (12-31-2012)
Old 12-31-2012, 09:51 AM   #3
Rewards Points: 13,458
The key when working with any premixed mud is thin layers.
A whole lot less sanding, and drys faster.
Old 12-31-2012, 10:23 AM   #4
Rewards Points: 5,974
If you are trying to fill a large area you or some pretty deep you may want to use hot mud/setting compound to fill then coat with regular mud.
Old 12-31-2012, 11:29 AM   #5
if it is cracking as it dries then its way too thick
Old 12-31-2012, 09:28 PM   #6
Registered User
Rewards Points: 5,498
Chemical setting or air-drying? I have a bag of 20 minute that won't set after three days... back to the store. Month ago I used a 20min. that set in 6 min. and it would not bond to the substrate, bubbled, and blister after the prime coat. Human error in mix when packaging, I figure. Wonder if it's local or all around.
Gary
Old 01-01-2013, 11:56 AM   #7
With quickset I like Ruco or ProForm over Usg brand both mix well and no problems drying, use 5 20 and 45 min, maybe the plants fault
drywall dust lorigobles Drywall & Plaster 8 12-01-2012 06:14 PM
In wall gutter downspout causing mold on drywall. chrispy35 General DIY Discussions 12 05-06-2011 10:35 PM
Bathroom drywall question... StevePax Remodeling 9 01-08-2010 02:30 PM
What's the best way to clean up drywall dust? ScottieBaseball Drywall & Plaster 2 02-09-2009 02:25 PM
Drywall dust in floorboard crevices ponchoman1 Flooring 1 04-30-2006 02:19 PM
