Loose Outlet In Ceramic Tiled Wall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-14-2013, 01:39 PM   #1
Rewards Points: 20
Loose outlet in ceramic tiled wall
I have an electrical outlet in a ceramic tile covered bathroom wall that is loose. The box is metal and the wall behind the tile is plaster. I've tried tightening screws and adding a concrete but the box still moves. Its a guest bathroom so it doesn't get much use but looks like I'll have some this summer and need to get fixed.
Suggestions?
hunt4cleanair is offline   Reply With Quote
Old 03-14-2013, 03:42 PM   #2
retired union carpenter
Send a message via Yahoo to coupe
Madison bars
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 03-14-2013, 04:17 PM   #3
Rewards Points: 20
What are madison bars?
Old 03-14-2013, 05:03 PM   #4
Rewards Points: 14,026
Got a picture?
Kill the power to the outlet, remove the cover and the screws holding the outlet in place.
Pull the outlet out of the box and push to the side.
Install a couple more screws into the side of the box.
Old 03-14-2013, 06:00 PM   #5
http://electrical.about.com/od/diypr...cutinbox_5.htm
The Following User Says Thank You to coupe For This Useful Post:
r0ckstarr (03-15-2013)
Old 03-14-2013, 07:23 PM   #6
Rewards Points: 5,994
I never knew that is what those were called. Learn something new everyday.
Old 03-14-2013, 07:29 PM   #7
I'd always heard them called plaster straps.
Old 03-15-2013, 03:48 AM   #8
Rewards Points: 20
Those madison straps sound perfect and while I don't think the outlet is next to a stud, add screws will help as well. thanks all
Old 03-15-2013, 07:21 AM   #9
provided you have enough room/slack you could pull the box and install an 'old work' box. they have wings that cam out when the screws are tightened that pul the box tight against the wall, with flanges that rest against the outside of the wall. Of course this would require removing and re-instaling the receptacle.
Sean'o ATHS is offline   Reply With Quote
Old 03-15-2013, 02:53 PM   #10
Rewards Points: 20
I picked up both an old box with the flaps and the madison straps and learned that it has a third name, locally "F" straps.
So here is the situation, I've got a nearly one inch wall of ceramic tile and plaster with a metal screen that secures the plaster. Picture shows this.
The old work box (blue) is thicker and longer than the old box. I've used files and a grinder to get the box to fit but the grinder started to chatter the tile. Depth is ok. I attempted to edge the grinder inward to get at the plaster but I just don't have enough clearance.
The F straps, once in and due to wall thickness and metal screen do not project enough to secure the old box.
Not sure where to go with this so looking for suggestions.
Old 03-15-2013, 06:15 PM   #11
Do you have access to a dremel? a carbide bit and little time you could shape the hole for the old work box just fine. If you don't have one I suggest you get one, they can be invaluable for DIY projects of all sorts along with crafts and other hobbies.
Old 03-15-2013, 08:29 PM   #12
Electrical Contractor
jbfan's Avatar
Rewards Points: 554
You may also want to buy longer screws for the flaps just to make it easier
The Following User Says Thank You to jbfan For This Useful Post:
sublime2 (03-15-2013)
Old 03-15-2013, 09:05 PM   #13
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
This here is the solution!
Yes.
sublime2 is offline   Reply With Quote
Old 03-16-2013, 09:46 AM   #14
Rewards Points: 20
Here's how this project finished...the Dremel was the fix. Got a tile cutter bit that worked nicely with some patience. After the first Dremel burned out just after the warranty period (ten years) I thought I could do without another one. The pictures show the box in the hole and the finished results. Not sure I got the flap up but it was tight fit.
Thanks all for the tips!
Old 03-16-2013, 11:16 AM   #15
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Nice job!
Outlet box outside of wall? tommy83 Electrical 1 11-28-2012 12:06 PM
30 amp GFCI wall outlet? CZ DIY Electrical 31 05-22-2012 09:03 PM
Putting wall ceramic tile over wall ceramic tile in bathroom shower Dottie43 Kitchen & Bath Remodeling 1 07-14-2011 11:38 AM
Electrical outlet controlled by a wall switch? rinlo Electrical 14 12-28-2008 10:30 PM
Converting wall outlet to power ceiling light? VEIK Electrical 3 07-08-2008 08:43 AM
