Looking For Ideas...drywalling A Clean Out - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-15-2012, 10:23 AM   #1
Looking for ideas...drywalling a clean out
I'm about to drywall my basement, and one wall has a clean out 3' off the ground.
I was going to make an access panel for it, and then make a dummy one so that the wall would look symetrical. The clean out is about a 1/3 of the way in from the adjacent wall.
Question is...how would you go about making this look presentable? For the real access, maybe throw some backing between the joists to screw the drywall too put in some hinges, then for finishing trim it with the baseboards that I will be using? Only problem I see is that it would easily pop open if I don't have some sort of locking mechanism on it...
Any other ideas? Just cover it, make some measurements where the clean out is, and hope that I won't ever have to get to it?
MLayden is offline   Reply With Quote
Old 06-15-2012, 12:14 PM   #2
Cut a hole in your drywall and use something like this: http://www.homedepot.com/buy/plumbin...el-144379.html
Looks fine IMO.
TSGR is offline   Reply With Quote
how to clean payne gas sensor? dapperdraker Appliances 3 06-26-2011 01:28 PM
Clean oil off of tools, also clean the inside of a compressor capslock Tools 1 12-23-2009 12:36 PM
How often do you clean your Paslodes Bearcreek Tools 1 08-24-2009 10:00 AM
Keeping Hardwood/Bamboo Flooring Clean? brandon272 Flooring 2 07-08-2009 10:39 AM
Leaking main drain clean out plug bucksone Plumbing 1 01-10-2009 08:42 AM
