Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 06-28-2012, 06:08 PM   #1
liquid nails b/ween ceiling sheetrock and joists
Someone told me i should always use liquid nails in addition to screws when installing drywall on ceilings that have a walking floor above them, in order to reduce noise transfer.
I was wondering how important and effective that is as i just screwed one sheet but forgot to use liquid nails.
Thanks.
Old 06-29-2012, 04:17 PM   #2
liquid nail does NOT go on sheetrock for ANY reason, the oils in it will bleed through the sheetrock and will always be a problem in the future. the right way is to make sure you use screws every 6 iches into strapping and no nails. also make sure your screws do NOT break through the paper otherwise the screw is usless.
if you want to reduce noise transfer i suggest you install resilient channel instead of strapping (1x3 fir).
3rdGeneration is offline   Reply With Quote
What do I do with 2x4 ceiling joists? benjamincall Building & Construction 28 12-29-2011 09:04 AM
Popping and snapping sound from wood I-Beam ceiling joists when gas log fire place in Okjtm General Discussion 7 12-27-2010 04:00 PM
sheetrock ceiling structure jcc3 Drywall & Plaster 3 11-28-2010 07:24 AM
insulation types i can use between current and new sheetrock on ceiling philbee62 Remodeling 4 08-05-2010 08:12 PM
