-   -   liquid nails b/ween ceiling sheetrock and joists (http://www.diychatroom.com/f101/liquid-nails-b-ween-ceiling-sheetrock-joists-148524/)
amakarevic 06-28-2012 05:08 PM
Someone told me i should always use liquid nails in addition to screws when installing drywall on ceilings that have a walking floor above them, in order to reduce noise transfer.
I was wondering how important and effective that is as i just screwed one sheet but forgot to use liquid nails.
Thanks.
3rdGeneration 06-29-2012 03:17 PM
liquid nail does NOT go on sheetrock for ANY reason, the oils in it will bleed through the sheetrock and will always be a problem in the future. the right way is to make sure you use screws every 6 iches into strapping and no nails. also make sure your screws do NOT break through the paper otherwise the screw is usless.
if you want to reduce noise transfer i suggest you install resilient channel instead of strapping (1x3 fir).
