Leveling Basement Ceiling For Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-02-2013, 09:55 PM   #1
Rewards Points: 85
Leveling basement ceiling for drywall
Hi There,
Based on a previous post, I have decided to drywall the ceiling in my basement that I am in the process of finishing. I am still finishing the framing/electrical, and planning out what I want to do for drywall.
My house was built in 2007, and uses engineered floor joists, so if they aren't level, they have to be close. I am worried about a wavy ceiling with drywall though.
I have read about strapping with 1x, but that seems really time consuming with shimming, especially if everything is fairly close. I have also read about RC channel, which adds some additional sound deadening. Would either one be more advantageous to flattening everything out for the drywall prep?
Thanks for any suggestions!
Josh
joshs is offline   Reply With Quote
Old 03-02-2013, 11:33 PM   #2
Rewards Points: 12,876
Take a piece of masons string and pull it tight on the under side of the joist to see if your worrying about nothing.
Old 03-03-2013, 08:33 AM   #3
automated tool pro
Rewards Points: 152
I think it depends on the size of the basement. If it's just one large open area I'd take the time to check it out. Smaller rooms I wouldnt worry so much.
About the line JoeCaption just suggested, Cut a few pieces of drywall about the size of a deck of card. Nail them in the corners of the room and run your line over the top and pull tight to the next piece and attach it. now, with another card deck sized piece of rock, go to each joist the line crossed and slip the drywall beneath it. The piece should fit snug beneath the line. If the line is too tight or there is space between the drywall, that joist is off. Keep repeating this process until you've decided whether going any further is worth it. Put a knockdown texture on the ceiling by using a pro would help too, but this is also a diy forum.
drywallfinisher is offline   Reply With Quote
Old 03-03-2013, 08:35 AM   #4
Rewards Points: 85
I will give that a try. Even if it is pretty flat, is it worth looking into the RC Channel for the sound deadening effect?
Old 03-03-2013, 08:42 AM   #5
automated tool pro
Rewards Points: 152
that's the way I would go to. and then check it agian with the line, adjusting the depth after its up.
Old 03-04-2013, 07:16 AM   #6
Rewards Points: 85
Thanks for the help! I will look into the RC Channel.
Basement ceiling question aggst1 Remodeling 9 05-07-2013 04:23 PM
Leveling a Basement Cement floor Tinkertom67 Flooring 0 08-14-2011 01:49 PM
Five inch ductwork in basement ceiling - how to end the run? drnormie HVAC 5 11-25-2008 10:21 AM
Arch ways, columns and ceiling drops - basement cobase Building & Construction 3 09-01-2008 04:21 PM
