Level Basement Ceiling Joists To Install Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-26-2012, 01:50 PM   #1
hrm
Level basement ceiling joists to install drywall
My ceiling Joists below my living room are not level and im trying to figure out most efficient method of installing a level ceiling while maintaining maximum ceiling height. Should I use 2x4s on the sides of the joists? Or sacrifice height with cross framing and shims?
hrm is offline   Reply With Quote
Old 12-26-2012, 05:23 PM   #2
Rewards Points: 760
Usually, here in New England, we use strapping (1x3's) perpendicular to the joists and attach the sheetrock to that. It helps smooth things out.
Unless the ceiling is really out of level you'll never notice.
AandPDan is offline   Reply With Quote
Old 12-26-2012, 05:41 PM   #3
automated tool pro
Rewards Points: 152
use one-by's
drywallfinisher is offline   Reply With Quote
Old 12-26-2012, 06:50 PM   #4
retired union carpenter
Send a message via Yahoo to coupe
the easiest way I've found, is rent an auto leveling rotating laser for a day, buy a set of 6" vice grip welders clamps $25.00. hang the laser 2" from joists, sister 2x4's to joists, clamping, raising/lowering as needed. no shims. if have help? make sure using same measurement
good luck
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 12-26-2012, 09:02 PM   #5
Rewards Points: 512
shim and install metal furring channel perpendicular to your joists. easier then trying to use twisted 1bys that crack and the furring channel comes in longer lengths then 8' and they are true and straight.
princelake is offline   Reply With Quote
How would you install drywall to ceiling??? oodssoo Drywall & Plaster 8 12-01-2012 03:50 PM
Basement Ceiling Drywall Master Brian Building & Construction 9 09-15-2011 12:21 PM
drywall basement ceiling Dgggless Drywall & Plaster 3 11-14-2010 09:43 PM
Hanging drywall basement ceiling from engineered wood I-beam joists ja_trusty Building & Construction 6 10-09-2008 11:06 AM
Ceiling joists spans drywall in a basement? Indianer Drywall & Plaster 14 06-09-2008 02:51 PM
