Level 5 Standards In Laymans Terms? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-26-2012, 12:31 PM   #1
Rewards Points: 85
level 5 standards in laymans terms?
What is the reality of a level 5 finish?
For example, when it says smooth finish-- what should the smooth finish look like.
I got a letter from my contractor certifying they did their work to the level 5 finish. This was a refinish of previously done walls.
What they did was repair the walls, and then rolled and brushed on porter speedhide primer/surfacer, adding more texture unfortunately to the walls, trying to get it to match up with their previous paint/drywall attempts.
They did not skim coat the walls, although they were supposed to.
I guess what I am asking for is clear definition of a level 5 finish result, for the drywall knowledge challenged.
Do waves and undulations for example still exist?
What is supposed to be uniform?
How is a level 5 finish properly inspected?
Thanks for any input!
steelgoddess is offline   Reply With Quote
Old 05-26-2012, 01:06 PM   #2
Sparky
Rewards Points: 510
http://www.nationalgypsum.com/ng/res...webversion.pdf
Should explain the differences between drywall 'levels'
Techy is offline   Reply With Quote
Old 05-27-2012, 03:10 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
techy did the work for you
google works wonders
Old 05-27-2012, 11:06 PM   #4
Rewards Points: 85
thank you for the link techy.. I had read that over a few times.
Old 05-27-2012, 11:22 PM   #5
Rewards Points: 85
You are absolutely right... I use it often... I've clocked hundreds of hours on it..in my crash course in construction I've had to take, since my home was obliterated and I set forth rebuilding...
However, sometimes all the technical data, and terms---doesn't easily correspond to the visual I am seeing, or the processed used--so I try to get a bit more insight if I can.
Old 05-28-2012, 12:20 AM   #6
Registered User
Rewards Points: 5,516
Here is a link I haven't posted on this forum, you may have not seen it yet:http://literature.usg.com/pdf/J510.pdf
Gary
Old 05-28-2012, 10:25 PM   #7
Rewards Points: 85
Thank you Gary. The link was very informative.
water level equalizing in sump pump basin? dmp Plumbing 21 04-13-2012 06:42 PM
Drilling Straight and Level miamicuse General DIY Discussions 10 03-16-2012 05:46 AM
Kitchen Cabinet installation, upper cabinets not level BillyJack Kitchen & Bath Remodeling 0 06-30-2010 08:07 AM
Is it bad to use mortar to level a floor? CB2007 Flooring 4 10-01-2008 08:38 AM
How level does a footing need to be? tripower Building & Construction 1 05-03-2007 08:59 AM
