#1 |
Level 5 Smooth Wall + Priming
The contractor I hired to do a Level 5 Smooth Wall finish in a new construction custom home insisted that priming the walls was a necessary step after putty coating them. He did not tint the primer and sprayed the white (flat) primer on using his Graco.
I've since learned that using a primer to highlight the imperfections is indeed industry practice but the primer needs to be tinted. Since he didn't tint the primer, it did not do what he said it would do, i.e. highlight the imperfections so that he could see what areas needed to be touched up. Does anyone agree or disagree with that statement? |
#2 |
You talking to me?
it doesn't make any difference as long as you got an acceptable finish.
#3 | |
Phoenix
Level 5 Smooth Wall + PrimingQuote:
After the wall is done, then its time for primer. But as far as i know the primer doesnt reveal the imperfections the spotlight does, hopefully before the primer gets sprayed on . Bottom line tho, if it looks good, its probably good
#4 |
Moderator
I agree, I've only heard of tinting the knock-down texture and sometimes the primer paint: “Drywall primer Applied as a first coat to the entire prepared
gypsum board surface with brush, roller, or spray, prior to decoration. Where final appearance is critical, the application of high quality high solids, drywall primer will minimize most decorating problems. For finish paints A good quality, white, latex drywall primer formulated with higher binder solids, applied undiluted, is typically specified for new gypsum board surfaces prior to the application of texture materials and gloss, semi-gloss, and flat latex wall paints. An alkali and moisture-resistant primer and a tinted enamel undercoat may be required under enamel paints. Consult with the finish paint manufacturer for specific recommendations.” From: http://gypsum.org/pdf/GA-214-07.pdf Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
| The Following User Says Thank You to Gary in WA For This Useful Post: | Axecutioner-B (10-28-2010) |
#5 |
You talking to me?
I've heard of and seen tinted mud and primers used but whether they are or not is irrelevant. As long as the wall meets an industry standard level 5 finish, how they get there is irrelevant.
they should have used blue board and plaster anyway. You finish the plaster, the wall is done if you want it to be. Since a plasterers work is to apply a flat smooth finish with no additional work needed, all this talk of tinting and sanding would be meaningless. |
#6 |
I will have to agree with nap. Level 5 done right is the best $$$ can buy for a smooth finish. Here is a link of (((one way))) to achieve a level 5 finish
http://www.youtube.com/watch?v=zZ4px...eature=related To the OP, Wait until your contractor is done. Then make a decision as to whether it meets up to your expectations.
#7 |
Phoenix
Level 5 Smooth Wall + Priming |
#8 |
I'm interested in knowing your opinions as to the necessity or importance of doing a prep coat (such as Hamilton's Prep Coat Plus) prior to doing the putty coat. The best outfit I know of here in Las Vegas does a Prep Coat as part of their procedure on all Level 5 jobs.
Thanks~ |
#9 | |
You talking to me?
that's good for them.
this is what hamilton says about their product: Quote:
Level 5 Smooth Wall + Priming does it really matter how the people you hire get to the end result as long as that end result is within industry standards and fulfills any applicable warranty? You questions are a bit cryptic, like you are trying to figure out what you should do when you do this type of work for a business. They surely are not questions the typical DIY'er. |
| The Following 2 Users Say Thank You to nap For This Useful Post: | Axecutioner-B (10-29-2010), mark942 (11-01-2010) |
#10 |
Drywall contractor
I agree, your questions might be better answered on a professional forum like drywalltalk.com.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops. |
#11 |
Xtreme DIY'r
2 threads on same issue merged
| The Following User Says Thank You to Scuba_Dave For This Useful Post: | Axecutioner-B (11-11-2010) |
| Display Modes | |
| How to make wall smooth after removing tile? | cheapchick | Remodeling | 20 | 04-09-2012 02:59 PM |
| Can I use wall liner to make my walls smooth?? | Michaela | Painting | 6 | 12-16-2009 09:45 AM |
| Temporary wall support question | discojv | Building & Construction | 7 | 01-25-2009 08:23 PM |
| Priming interior wall repaints | dyier | Painting | 3 | 01-14-2008 08:10 PM |
| Load Bearing Wall? | Traybae | Building & Construction | 1 | 11-05-2006 02:01 PM |
