Large Gap Between Ceiling Drywall And Wall - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-29-2014, 09:13 PM   #16
Rewards Points: 422
Originally Posted by Gary in WA View Post
I would slip a 1/2" x 6 x cavity width siding board or similar up/on the gap and screw through the big sheet to secure it, just for backing. Add some screws, and finish as posted. Put a couple of screws halfway in at the thick face/edge of the board to maneuver it from. Sorry about that....
Gary
Thanks Gary. I have some scrap 1/2" OSB or plywood I can use. So once it's in place, it would be lying flat on top of the ceiling drywall, correct? So the bag mix mud will adhere to the OSB? Would 1/2" plywood work better?
Jim McC is offline   Reply With Quote
Old 01-30-2014, 03:05 PM   #17
Rewards Points: 144
I don't see how you could use 1/2" material.You need something to support the cracked drywall above.Like maybe a 2X4 between the joist Something you can you can screw into.Then cut any loose material around the crack.Prefill with some mud.Let dry and then tape and mud as usual.
mako1 is offline   Reply With Quote
Old 01-30-2014, 04:06 PM   #18
Rewards Points: 422
What cracked drywall? I don't know where you read that.
The Following User Says Thank You to Jim McC For This Useful Post:
gregzoll (01-30-2014)
Old 01-30-2014, 05:15 PM   #19
Registered User
Rewards Points: 526
Yes, plywood is better than OSB, here. Be sure to fasten it securely. Glad we could help.
Gary
Old 01-30-2014, 06:34 PM   #20
Rewards Points: 422
Gary
Thanks Gary. Just to make sure I understand you, the hot mud will adhere to the plywood and not fall out? The gap is on the ceiling sheet(where it meets the top of wall), NOT the top of wall.
Old 01-31-2014, 07:50 PM   #21
Registered User
Rewards Points: 526
Add a handful of screws in the ply, run them in just below the drywall surface to hot mud over.
Gary
Old 01-31-2014, 09:36 PM   #22
Rewards Points: 422
Gary
OK thanks.
Old 02-03-2014, 08:40 PM   #23
Professional
TotalHomeworx's Avatar
I would just fill it with hot mud (sheet rock 20 or 45 or 90) and mix it thick so it stays in there. Let it dry. Flat tape the ceiling (half on the ceiling half on the set hot mud) with regular compound then tape the corner with compound.
TotalHomeworx is offline   Reply With Quote
Old 05-20-2014, 10:50 PM   #24
Rewards Points: 978
what if the ceiling drywall is extended over the top of the wall drywall
federer is offline   Reply With Quote
Old 05-21-2014, 11:48 AM   #25
Rewards Points: 144
You did say gap and I said crack.I gave you good advice either way on a 5/8" GAP.
Question: BNC cables through attic (studs to wall, or ceiling drywall?) eatmyturf Electrical 4 04-05-2013 10:25 PM
Drywall Ceiling against a Curved Wall kegnut Drywall & Plaster 9 09-14-2012 06:12 PM
Adding wall with door opening - sloped ceiling and no joist for top plate Jebross Remodeling 11 01-11-2012 09:34 AM
In wall gutter downspout causing mold on drywall. chrispy35 General DIY Discussions 12 05-06-2011 10:35 PM
Hanging Ceiling Drywall AFTER Wall Drywall? mfleming Drywall & Plaster 10 10-06-2008 03:32 PM
