Large Bulge In Wall - Cause? - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-09-2013, 08:36 PM   #16
long island, NY
yeah, I'm totally clinging to that to maintain my sanity. If both sides of the wall were f'ed up, I'd be making a mess in my undies. Would be super duper expensive, and I'd definitely would have to hire out several top tier pro's to fix it. I'd be broke!
diy'er on LI is offline   Reply With Quote
Old 03-09-2013, 08:42 PM   #17
long island, NY
Originally Posted by mech_gui View Post
Riper' down then we want to see!!
But what am I looking for?! I want to conclusively find what caused this. If I'm not confident, I don't want to "destroy the evidence" and then call in a pro.
I mean, if I find a stud that is pushed outwards, yeah, that's obvious. concerning (would call in a pro, maybe an engineer to figure out why that happened!)
but if it's only the surface drywall, what should I look for?
Should I be looking for screws that are farther apart than 12"?
what else?
Old 03-09-2013, 08:45 PM   #18
long island, NY
Originally Posted by joecaption View Post
Could be a lot of things and you as a home owner DIY may not even now what's wrong when looking at it.
Were you one of the many effected with the last hurricane?
Once it's open up repost,
May have to call in on site pro engineer to look at it to figure it out.
do you think pictures could capture the problem? I mean, it's difficult to capture the plumbness of framing in a picture.... or do you think it would likely be sufficiently obvious? If you think it would be, I'll tear that beast up!
Old 03-09-2013, 08:50 PM   #19
Rewards Points: 83
but if it's only the surface drywall, what should I look for? can you push the sheetrock back against the studs at all?
what else?
Take more pictures cell phone movie even.
How close were you to the high winds? High winds can shove a house causing big shifts in the structure framing. They could have " racked " your roof a little.
Are there other houses in your area with hurricane damage?
mech_gui is offline   Reply With Quote
Old 03-09-2013, 09:01 PM   #20
long island, NY
well, that's almost an annual issue here on LI. Keep in mind, it's not like evil southern hurricanes (100mph+ winds) they tend to pitter out a bit by the time they reach us. Usually Cat. 1 at best... more often tropical storm level.
Most of the house damage over here was caused by trees hitting homes. Not wind damage. Siding/roofing was undamaged by the last 2 hurricanes.
This bulge was present but slight several years ago. In the last year?, it has traveled an ugly road and gotten much worse. Not sure what's causing it. The slab beneath has not shifted... the opposite side of the wall seems fine, the roof is fine....
OK, my hubby and I will tear at the beast. Don't think we have the time to make and repair such a giant mess before easter, but we'll do it soon.
thanks so much for your input everyone!!!!!
Old 03-10-2013, 12:26 AM   #21
Registered User
Rewards Points: 5,204
If an exterior south or west wall I could understand; http://www.paintsource.net/pages/sol...ood_shrink.htm
As it has a floor on the other side, I'm going with the rim joist shrinking (because it is drying out from seasonal changes) now that the heat is on after the mild weather... fig. 3; http://www.buildingscience.com/docum...d-but-strange/
Although, that is an interior wall, but it is probably a "bearing" wall as well, supporting the floor joists of the up-stairs room. You may find the fasteners are in the studs above/below or the drywall joint is on the rim joist and it needs an "expansion joint" in the drywall boards. I'd cut a small section out from both upper/lower board joints and paper tape it over a 1/4" gap left for movement, or buy the correct drywall trim; pp.6, fig. 6; http://bestdrywall.com/files/ReduceCallbacks.pdf
Gary
Old 03-10-2013, 11:09 AM   #22
long island, NY
Gary
The expansion joint issue very likely could be it! The bulge is precisely at the point of my bedroom floor joists... Thanks so much for your input.
It would be lovely if that were the solution. Obviously, this wall's drywall is so messed up it needs to be replaced. Would be fabulous if drywall were the only repair and everything is structurally sound beneath.
Fingers crossed!
Old 03-10-2013, 11:21 AM   #23
Rewards Points: 216
if you can't do it for 2+ weeks. you must not be that worried about doing 10 mins of work. to be able to see, or at least take pics for us to see, what is going on in there.
Fix'n it is offline   Reply With Quote
Old 03-10-2013, 11:39 AM   #24
Rewards Points: 2,516
Is this the bulge? Can you post a picture and stand a little further back?
hammerlane is offline   Reply With Quote
Old 03-10-2013, 02:21 PM   #25
long island, NY
no actually, it's the giant crease about 3-4 ft above it (near the 1" hole I made on the rt side and a few inches below the brown moulding.).
What you pointed out, however, is a secondary seam that just recently began to bulge at roughly the 4' mark on the wall. (roughly 2 ft above the staircase landing)
Sorry for the disorienting picture! It's the best I can do because it's a stairwell. I took the pic standing on roughly the 8th step, looking downwards towards the landing (which is equivalent to the 4th step of the staircase). The staircase is covered w/ chocolate brown carpeting....
The recent appearance of that second seam made me almost think that there is pressure pushing down on that drywall sheet from above, causing the larger/higher bulge and this lower seam appearance.
Old 03-10-2013, 02:24 PM   #26
long island, NY
oh, I've been skooled by you. You are definitely right, sir. There is zero reason for me to hesitate in demoing the drywall of a massive wall right in the middle of my home right before easter.
And of course, it would only take 10 min for a diy'er with only moderate drywalling experience to fix this issue by installing scaffolding on a staircase, replacing drywall from 2ft to 10 ft in the air, taping, skimming, and painting before easter day.
I must be lazy to delay this until after the holidays.
The Following User Says Thank You to diy'er on LI For This Useful Post:
oh'mike (03-10-2013)
Old 03-10-2013, 04:24 PM   #27
Rewards Points: 5,974
He's not talking about doing the whole repair. Just take a few minutes to open up and see what is going on. To make a bulge like this something has moved or broken. It could be anything from something minor to a major support has broken. Drywall does not bulge and crack for no reason.
Old 03-10-2013, 05:43 PM   #28
long island, NY
I know, but I can't exactly have a house full of guests with a wall missing. KWIM? Kinda obvious from my statement "gotta be after easter"
Old 03-10-2013, 06:07 PM   #29
DIY staff
Rewards Points: 7,174
Long Island----your house is not in danger of collapse---
If the drywall on the other side of that wall appears to be solid and un wrinkled---the chances are you have en expansion issue that finally caused the drywall to break loose from it's glue and nails.
This will wait until you have time----
What I suggest is the removal of the damaged drywall---then an assessment of the framing---either by the members here or a carpenter or other structurally knowledgeable person----
Correct the framing problem if there is one--then replace the drywall---
This will be a bit disruptive---you will have half a day protecting the area and setting up the scaffold ---an hour fixing the framing---then a couple hours hanging----then two or three days applying mud and waiting for it to dry----
This does not look like an emergency----
Just a big pain in the bottom.
My money is on a stud that is bowed and loose drywall---
How old is the house?
1970s frequently used glue and nails----bad glue----loose sheets are common from that time period.
diy'er on LI (03-10-2013)
Old 03-10-2013, 06:32 PM   #30
long island, NY
Oh'mike, you are the person who gave the sage advice on the original thread I read from a few years ago on a similar topic
1975 is when the house was built to be precise. yeah, I don't doubt crappy glue was used. And yeah, they did nail the drywall. Why oh why.... some parts of code in those days was highly suspect, to say the least.
That's what I'll do, I'll demo after easter, see what evils lurk behind.... post a few good pics for the wonderful experts on this site, and see if they think I need to hire a pro to give a professional structural assessment in person, or if I can correct it on my own.
I loathe this... just because I'm not experienced at navigating super awkward locations. 16 ft ceilings.... will be tons of fun to build a scaffold on that staircase to remove wallpaper/drywall. Guess I should make lemonade from the lemons and replace the outdated light fixture over the stairs, and paint the opposing wall at the same time. Then I hopefully won't have to climb up there for another 15 years....
I really sincerely appreciate everyones input. You guys totally rock. I want you to know you really help out little guys like me more than you know.....
ToolSeeker (03-10-2013)
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 01:26 PM
Drywall Bulge after installed TV wall mount tstecko Drywall & Plaster 15 03-23-2010 08:35 PM
Replacing large retaining wall notfromaroundhere Landscaping & Lawn Care 6 12-17-2008 01:30 AM
baseboard around a bulge in wall henpest Carpentry 6 08-26-2008 06:57 AM
