Knife For Tight Corners? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-13-2013, 07:19 PM   #1
Knife for tight corners?
Hi all,
I've looked around at different stores but can't find a knife or tool that allows me to mud tight corners - 60 degree inside corners at the top of a stairway.
Any ideas? Do angled knives exist for things like this? How is it normally finished?
bergsj is offline   Reply With Quote
Old 07-13-2013, 07:26 PM   #2
Rewards Points: 13,458
Without a picture it's hard to say.
I just make do with my regular drywall knives.
http://www.all-wall.com/Categories/C...er-Trowel.html
Old 07-13-2013, 10:07 PM   #3
Here is a pic. I'm trying to finish the wall side but I can't fit any of my knives up into the corner.
Old 07-14-2013, 06:16 AM   #4
DIY staff
Rewards Points: 7,174
Yes, angled knives are availavle from a drywall supply house like Ames---
In a pinch, a pair of tin snips can be used to modify an old knife----that is what I do when I can't find my angled knife----
Old 07-14-2013, 07:04 AM   #5
Rewards Points: 5,974
Also the big box stores have sets of plastic knifes you can alter to fit special situations.
The Following User Says Thank You to ToolSeeker For This Useful Post:
oh'mike (07-14-2013)
Old 07-16-2013, 08:40 PM   #6
automated tool pro
Rewards Points: 152
with such a short span you could just use regular paper tape, let it dry and then coat each side.
drywallfinisher is offline   Reply With Quote
The Following User Says Thank You to drywallfinisher For This Useful Post:
oh'mike (07-16-2013)
Old 07-16-2013, 08:45 PM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 1,454
I had the same problem this past weekend.....
I took a piece of rubber base board and used it as a 'former'....it actually did a decent job.....
BTW....I have a new appreciation for guys that do drywall....on a positive note....it's a good workout for the arms....
The Following User Says Thank You to ddawg16 For This Useful Post:
drywallfinisher (07-17-2013)
Preparing drywall mud, all purpose green bucket Arsinek Drywall & Plaster 27 06-11-2013 06:34 PM
Curved corners where drywall meets? SouthGAreno Remodeling 12 01-17-2013 03:10 PM
recommend a book nvr2low Drywall & Plaster 9 12-21-2011 11:37 PM
corner bead on existing wall stallinc Building & Construction 12 01-30-2008 07:38 AM
