Knee Wall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-09-2011, 12:36 AM   #1
Knee wall
I am in the process of hanging drywall in an upstairs addition. I have most of the sloped ceiling already in place. When I hang the pieces on the knee walls, should I cut the top at an angle to match the sloped ceiling, or simply butt the end up against it with the finished edge along the ceiling?
tim250f is offline   Reply With Quote
Old 11-09-2011, 01:10 AM   #2
iminaquagmire's Avatar
Rewards Points: 338
Either way. If you just use the tapered edge, fill the gap and make your bed for your tape at the same time. The tapered edge also allows for a little less buildup in the corner. Less to feather out.
iminaquagmire is offline   Reply With Quote
Old 11-09-2011, 06:38 AM   #3
DIY staff
Rewards Points: 7,174
Seriously consider using 'Straight Flex' for those off angle corners when you get to taping that area---
It is nice and stiff and will yield a nicer joint than paper.
knee wall attic access doors WillK Building & Construction 4 12-01-2010 07:32 AM
How to prevent mold in knee wall cabinet dressers cxcarl Building & Construction 1 03-13-2010 08:01 PM
Framing stair knee wall... bparise Carpentry 6 11-14-2009 01:03 AM
Building knee wall in basement, best approach? RyanD Building & Construction 6 07-04-2009 02:07 PM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 10:18 AM
