Kitchen Walls, Corner Not Square, Walls Wavy! - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-09-2011, 11:12 PM   #1
Rewards Points: 682
Kitchen walls, corner not square, walls wavy!
We have an old kitchen we want to replace the cabinets. I've torn out the cabinets and found one corner is not square, and the walls are quite wavy. I haven't checked to see if the walls lean in or out.
What makes these walls wavy? And if I gut the walls and replace the drywall, can that fix or improve things?
darsunt is offline   Reply With Quote
Old 11-09-2011, 11:32 PM   #2
Rewards Points: 682
Also there was a tile splashboard above the tile counter, and one of those sheets of fake plastic tile behind the stove. Knocking off the tiles is causing a great deal of damage. Would it be better just to tear off the drywall and replace it?
Old 11-10-2011, 06:38 AM   #3
DIY staff
Rewards Points: 7,174
Typically the drywall is removed in the back splash area---We remove a 4 foot wade section ---this puts the seam behind the cabinets and saves taping.
Opening the walls allows you to upgrade the electrical---add under cabinet light wiring --and gives you a nice clean wall behind the counter top.
If the walls are wavy--Removing the entire wall of drywall will be needed in order to sister in studs or otherwise flatten out the mess.
Old 11-10-2011, 07:36 AM   #4
Rewards Points: 320
I went through the same thing not too long ago. My walls were uneven due to old (180yrs) framing mixed with new framing, and probably hurricanes, etc over the years bowing the wall out. Here's the link to my post on the matter.
getting studs on a wall even
autx790 is offline   Reply With Quote
Old 11-11-2011, 12:14 AM   #5
Rewards Points: 682
I'm tearing off the drywall now. Most likely I'm looking at bowed studs?
Old 11-11-2011, 06:14 AM   #6
DIY staff
Bowed studs---mismatched thicknesses---plumbing pipes---
It's like unwrapping a Christmas present from that weird relative---You will only know when the wrappings are off!
tcleve4911 (11-11-2011)
Old 11-11-2011, 07:23 AM   #7
Ironlight's Avatar
Sistering out the studs to make the wall flat should not be too much of chore. Just be sure to be careful with the edge of your demolition that you don't make it hard for yourself to join up the new to the old. That's true along the ceiling also. And don't worry about making the corner of your kitchen perfectly square if that seems like it's not possible. You can always shim out your new cabinets to deal with that.
Ironlight is offline   Reply With Quote
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
Removing 2 walls - corner post issue (pics) LadyNimue Building & Construction 7 01-06-2008 12:35 PM
Smoke on walls in kitchen diylady Painting 7 07-14-2007 10:09 AM
tin walls and kitchen cabinets MKemnitzer General DIY Discussions 6 01-05-2007 03:47 PM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 10:23 PM
