Joint Tape - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-13-2013, 05:27 PM   #1
analogmusicman's Avatar
Rewards Points: 560
joint tape
I've got a roll of "fiberglas" (at least I THINK it's made of that )joint tape that I got at HD. unlike regular paper joint tape, one side is sticky. does that mean it should be stuck to the joint first THEN mud applied?
tnx,
analogmusicman is offline   Reply With Quote
Old 01-13-2013, 06:45 PM   #2
Rewards Points: 6,652
Yep. Mainly just used for older plaster walls, or quick patch jobs. You can get the Paper tape that also has the sticky backing, but best way to do the job, is good ole paper tape with mud first, then mud over the tape.
The Following 3 Users Say Thank You to gregzoll For This Useful Post:
joecaption (01-13-2013), Nailbags (01-17-2013), ToolSeeker (01-14-2013)
Old 01-13-2013, 06:50 PM   #3
Rewards Points: 13,300
Mesh tape requires a wider knife to get enough build up to even out the wall.
Old 01-14-2013, 01:08 AM   #4
Rewards Points: 1,092
i also read here that the fg tape is too rigid, and when the 'rock flexes a tad you'll get a crack with it. dunno.
Old 01-14-2013, 08:41 AM   #5
Rewards Points: 5,974
Go on almost any drywall site and there is at least one tread going on the debate of paper vs mesh tape. I favor paper so keep that in mind. I think the one thing you can do to help with the idea of mesh being more prone to cracking (I think it is ) is to use hot mud (setting type over drying type) for at least your first coat, preferably the first 2 coats, then all purpose for the third coat. The setting type mud can be found at the box store in white bags and they will say 20min,40min, or 90min this is the approx. time it takes it to dry. There are some rules for mixing this kind of mud, if you decide to go this way come back and we will go over them.
The Following User Says Thank You to ToolSeeker For This Useful Post:
princelake (01-14-2013)
Corners are cracking as joint compound dries hoffmandirt Drywall & Plaster 6 04-24-2012 10:33 PM
Mesh Tape dustinfox Drywall & Plaster 10 03-02-2012 10:53 PM
CBU Joint Issue? cobrakai Kitchen & Bath Remodeling 1 01-19-2011 10:11 PM
Frozen Hot Water Pipes TravisW Plumbing 11 12-10-2009 06:26 PM
Need to Patch Holes on Newly Skimcoated Wall: Use Tape? Lovegasoline Building & Construction 6 12-06-2009 04:31 AM
