Joint Compound And Drywall Seams - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-06-2011, 11:59 PM   #1
Joint compound and drywall seams
What can be done to avoid joint compound showing when painted over? Sanded many times and it seems flat until I paint over it. Drywall seams look terrible......please help!
Stacywov is offline   Reply With Quote
Old 03-07-2011, 10:32 AM   #2
MikeKy55's Avatar
Rewards Points: 254
Did you primer first? If not, it will look like that.
MikeKy55 is offline   Reply With Quote
The Following User Says Thank You to MikeKy55 For This Useful Post:
DangerMouse (03-07-2011)
Old 03-07-2011, 03:17 PM   #3
What sheen paint are you using? High the sheen the more will show....also consider a high build primer that has a thicker dry film. This product will cover up many imperfections in a wall.
BMDealer is offline   Reply With Quote
Old 03-07-2011, 03:29 PM   #4
Rewards Points: 558
Primer, primer, always primer...
epson is offline   Reply With Quote
Old 03-07-2011, 03:55 PM   #5
Pictures help on something like this. Have you even done drywall before? If not its all about the finishing and doing it right.
Drywall is one of those things that you can just wing it and get it right. Muddling and taping is an art form perfected by those crazy french Canadians!
Everything I state on this forum is an opinion I have developed based on my experience and research as a professional.
wnabcptrNH is offline   Reply With Quote
Old 03-09-2011, 05:46 PM   #6
Drywall contractor
Rewards Points: 1,070
Gloss paint in any form is not your friend if you're not adept at finishing....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 03-13-2011, 03:55 PM   #7
Masters in Drywall
MnDrywallRanger's Avatar
It may be what is called "flashing" or "photographing". Even with a perfect taping and sanding job the seams may show after painted....especially on walls where window light shines down the length of them.
Flashing is caused from the difference in the smoothness of the mudded seams vs the slightly textured paper on the sheetrock, plus the paper on the sheetrock may have gotten fuzzed up from sanding giving it even more contrast from the smoothness of the mud. There are advanced taping and painting strategies to avoid this during the process...
On new sheetrock quality primer is a must with proper backrolling and enough paint applied. Too often homeowners who paint newly finished drywall do not apply enough primer or skimp on the quality of brand of primer.
The other possibility it is just a poor taping job that didn't show till the paint was on. One way to tell if it truly is from the mudding is to place a 500w light right next to the wall and shine it down the length of the wall with all other lights off if possible. Any flaw will show(shadow) and it will be easier to tell if the seems are humped, hollow, or just plain flashing.
MnDrywallRanger is offline   Reply With Quote
Venitian plaster faux painting using drywall compound? crankcase Painting 3 02-18-2011 08:51 PM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 06:50 PM
re: drywall compound over old lath gramps416 Drywall & Plaster 5 01-17-2009 09:51 AM
Hairline crack in joint compound elbee Building & Construction 10 12-02-2008 06:57 PM
Re-doing Spackle mpedrummer Remodeling 4 08-12-2008 04:52 AM
