-   -   joint compound on concrete wall (http://www.diychatroom.com/f101/joint-compound-concrete-wall-105529/)
skuter1 05-25-2011 10:29 AM
does joint compound adhere easily to concrete blocks as in a basement or is painting more practical?
mustangmike3789 05-25-2011 10:33 AM
Originally Posted by skuter1 (Post 654616)
does joint compound easily to concrete blocks as in a basement or is painting more practical??
whatcha talkin about willis.:huh: i think that you may have left some wording out..
dberladyn 05-26-2011 12:33 AM
Yes, it will adhere.
There are certain steps you need to take though.
First, don't even attempt it if that concrete is damp on the other side, IE if it's an exterior foundation wall. Next, your mortar joints may be a problem down the road. If they crack, your finish will crack. If you are hell bent on doing this, skim the entire block surface with Concrete Fill (and imbed sheets of fibreglass mesh for insurance), then skim with regular drywall compound.
My advice.. laminate 1/2 drywall to the blocks. You can use Taping Compound as adhesive.
Dan
