Which Joint Compound? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-22-2010, 05:37 AM   #1
artlover13060's Avatar
Which joint compound?
I'm going to start taping and mudding my basement ceiling job this weekend. Could you please advise about the various types of joint compound? I did a search and found an old thread, but it was from 2005. It was resurrected in 2008 and there was some discussion that the old info might not be up to date given new products.
BTW, I just bought a Troy drywall lift from Amazon. I'm very pleased with how helpful it is. I am a 57 year old woman and was able to hang the ceiling almost entirely by myself. The only problem I have is lifting the sheets onto the contraption. Non-handy hubby has to help with that part.
artlover13060 is offline   Reply With Quote
Old 01-22-2010, 09:37 AM   #2
Rewards Points: 40
I've always used yellow (box) compound for applying tape and green (box) compund for the remaining coats.Try to look for the manufacture date on the box as some places with low product turnover may have old stock.Recommended use date is six months and if really old could be lumpy.Were you doing the walls as well?May as well do it all at once and only have one mess to clean.I've also used a sanding attatchment for my shop-vac when sanding.If you go that route be sure to get a drywall filter for the vaccuum because that dust will destroy the brushes and armature real fast.I'm sure it's shortened the life of my machine but was worth it to me.
daveb1 is offline   Reply With Quote
Old 01-22-2010, 09:43 AM   #3
premixed compound in 5gal buckets, I like first coat with durabond 90.
Old 01-22-2010, 10:51 AM   #4
yummy mummy's Avatar
Rewards Points: 1,016
You go girl......
I used an all purpose compound, which I thinned down with water.
If you have never done this before, you need a compound that will not dry very quickly.
Practice first. You will get the hang of it.
I also installed my drywall on the ceiling. I did not get a drywall lift, so I ended up cutting them in smaller pieces in order for me to lift them.
So, needless to say, I had soooooooo many seams. I decided that I really like textured ceilings.......lol So I did a nice texture by hand.
Good luck.
yummy mummy is offline   Reply With Quote
Old 01-22-2010, 10:55 AM   #5
get a mixing paddle and good 1/2" drill for mixing. I never add water to premix until slick/finalcoat and very little then
Old 01-22-2010, 10:21 PM   #6
I think that would be way too thick for first coat, second coat and third coat, even for a fourth coat. I did four coats on mine. Better many thin coats than fewer thick coats.....in my opinion anyway.....
Old 01-23-2010, 05:01 AM   #7
paper hanger and painter
chrisn's Avatar
Rewards Points: 464
With the pre mixed compound there should be no need to add water, that is why it is pre mixed.
Old 01-23-2010, 09:00 AM   #8
I bought light weight all purpose. How that was a good choice. I am going for a smooth ceiling. I've done this before with pretty good results.
Daveb1 - the walls are already done. I'm replacing a suspended ceiling with drywall.
Old 01-23-2010, 01:46 PM   #9
Rewards Points: 40
You can't usually go to far wrong using what you're comfortable using.Have a mud-flinging good time!Show us some pics when you're done!
Old 01-23-2010, 02:33 PM   #10
Too thick for my liking.....
spackle versus joint compound... joeyboy General DIY Discussions 13 01-06-2016 05:09 PM
What To Prime Wood With to Accept Joint Compound? Lovegasoline Building & Construction 19 11-03-2009 05:04 AM
Will joint compound stick to Zinsser 1-2-3? Lovegasoline Building & Construction 13 09-28-2009 10:55 AM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 05:50 PM
Hairline crack in joint compound elbee Building & Construction 10 12-02-2008 05:57 PM
