Joint Compound: - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-07-2014, 09:37 AM   #1
Rewards Points: 67
Joint compound:
I'm doing a small basement rec room, about 20 4 x 8 sheets.
I don't want another half-empty 5 gal. container sitting around the house!
Is there one type of compound that will do a good job for each step of the way, or do I need to buy all-purpose for the start and the lighter stuff for the final coats?
oldberkeley is offline   Reply With Quote
Old 03-07-2014, 09:44 AM   #2
DIY staff
Rewards Points: 7,174
Buy the products that will do the best job----
Multipurpose for the tape----then light weight topping compound for the final coat--
Also---powdered easy sand for filling voids and corner bead---the cost will be worth it--
Old 03-07-2014, 10:34 AM   #3
Rewards Points: 67
Truthfully, it doesn't have to be the "best" job, just adequate.
I'm trying to avoid buying two products, much less three.
Old 03-07-2014, 10:55 AM   #4
Rewards Points: 626
Then just buy a box or bucket of all pourpose mud. call it good end of story.Not the way I do it but if you just want meh good enough get the green lid add about a pint of water mix to a sour cream texture and go for it. If you want to do it right a box of taping mud, then a box of topping mud. still have to add about a pint of water to each and mix well.
Nailbags is offline   Reply With Quote
Old 03-07-2014, 10:57 AM   #5
Rewards Points: 626
Oh and the half empty bucket. you need to look at it as half full. LOL just take the left over to the land fill and call it good.
Old 03-07-2014, 01:02 PM   #6
Thanks Nailbags and oh'Mike!
I just learned something about joint compound from you guys that I didn't know before. No matter how much you think you know...you can always learn more.
Reminds me of a quote from one of my favorite film actors:
"A man's got to know his limitations." --Clint Eastwood aka Dirty Harry
DIYRemodeler is offline   Reply With Quote
Old 03-07-2014, 04:42 PM   #7
Rewards Points: 256
use a 5 gallon bucket of all purpose to set the tape and paper beads if your using paper beads , if you have leftover all purpose just add topping mud to it and use it up on the fill coat , then use straight topping for the finish coat . does not hurt to mix them together so you can use it up .
oldrivers is offline   Reply With Quote
Old 03-07-2014, 09:46 PM   #8
Rewards Points: 512
this is a diy site and homeowners dont want to spend a ton of money on a bunch of different products if they dont have to. i find dust control does ok all around. it sets the tape ok, fills ok and finishes ok. ok?
the proper tested and true way is to prefill with easy sand, set the tape with green lid mud and finish with a premixed topping compound.
princelake is offline   Reply With Quote
Old 03-07-2014, 10:11 PM   #9
Rewards Points: 626
Easy sand has no glue is the mud and the tape will not bond correctly. This is a DIY and proced at your own risk from advice give out.
Old 03-07-2014, 10:21 PM   #10
Rewards Points: 512
I didnt say to tape with easy sand. I said prefill with easy sand and then tape with green cgc
The Following User Says Thank You to princelake For This Useful Post:
oh'mike (03-08-2014)
Old 03-08-2014, 12:48 AM   #11
Rewards Points: 256
dust control is usually the most expensive though . if you don't want extra 1/2 bucket of mud left over just run all your seems extra wide until its used up . take your hawk and trowel and go nuts . skim coat all the sun walls etc .
Old 03-08-2014, 12:57 AM   #12
Rewards Points: 256
you can tape with easy sand it helps to wet the tape first though . I do that all the time with patches .
Old 03-08-2014, 06:40 AM   #13
Rewards Points: 6,034
If by easy sand you mean dura bond hot mud you absolutely can tape with it. If by easy sand you mean like topping or the ultra lite then no you can't tape with it.
The Following User Says Thank You to ToolSeeker For This Useful Post:
Nailbags (03-09-2014)
Old 03-08-2014, 07:04 AM   #14
Rewards Points: 808
Yes this is a DIY site. That doesn't mean homeowners are asking how to incorrectly hack together every project in a slipshod manner and how to cut corners and install code violations every step of the way. My assumption is that HO's ask questions when they're facing an issue beyond their DIY capabilities. By doing it yourself, you're already saving a boatload of money. Trying to "save" a few more dollars by screwing up the finish surface of walls and ceilings because a leftover 1/2 pail of mud is "inefficient" is just downright foolhearty.
Gee, I wonder why the pros don't do it that way then?
IslandGuy is offline   Reply With Quote
Old 03-08-2014, 08:33 AM   #15
Jb1234's Avatar
Rewards Points: 87
Drywall mud is so cheap, it would be ridiculous to skimp on it or worry about having a half pail. I'm sure a church, a shelter or another organization would be happy to have the donation if they're doing any remodel work.
Jb1234 is offline   Reply With Quote
Is frozen joint compound acceptable once it has thawed? Deck Drywall & Plaster 11 01-02-2013 11:12 PM
Corners are cracking as joint compound dries hoffmandirt Drywall & Plaster 6 04-24-2012 09:33 PM
dots in joint compound insearch Painting 2 06-01-2011 09:44 PM
Will joint compound stick to Zinsser 1-2-3? Lovegasoline Building & Construction 13 09-28-2009 10:55 AM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 05:50 PM
