Joint Compound - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-07-2013, 09:48 AM   #1
Rewards Points: 119
Joint Compound
Why all the different types of compound? I stopped at the store to pick up more and in the Sheetrock brand they had All Purpose, Lightweight All Purpose, Lightweight All Purpose with dust control, Ultralight All Purpose, and topping compound.
KStatefan is offline   Reply With Quote
Old 07-07-2013, 11:58 AM   #2
Architectural Sculptor
RWolff's Avatar
Rewards Points: 502
Marketing, money, and competition when you can offer "47" different variations on the same thing and promote it x 47 you sell more than if you only have one product.
If you can offer 47 "different" products and your competitors can only offer two, you get the lion's share of the store shelf space and more importantly- sales.
It's the same gimmick they used to use for a dozen "different kinds" of varnish in the old days, good grief they even had "church pew" varnish!
RWolff is offline   Reply With Quote
The Following User Says Thank You to RWolff For This Useful Post:
KStatefan (07-07-2013)
Old 07-07-2013, 06:47 PM   #3
DIY staff
Rewards Points: 7,174
Here are the uses----
All purpose---Green lid---contains glue and is used to set the tape--rather hard to sand--can be used to fill corner bead and use for fill coat---many pros use this for top coat also---
Light weight--blue lid----used for final top coat--creamy and very easy to sand---not good for much else---never use to set tape or fill corner bead.
Powdered 'easy sand'(white bag)---hard to sand---sets in 5--20--45--90 minutes---used to fill voids and miscuts--can be used to set paper--fill corner bead --fill coat---
Some people use it for the top coat but you better be good with a knife as it is really hard to sand.
Durabond (brown bag)--for exterior use mainly---water resistant--hard as concrete--do not plan on sanding this one---
MTN REMODEL LLC (07-12-2013)
Old 07-07-2013, 08:28 PM   #4
Rewards Points: 5,974
It's the same as primer why are there so many kinds of primer. They all serve a purpose. As for drywall compound you only scratched the surface. There is also machine mud, taping mud and the list goes on.
Old 07-07-2013, 08:45 PM   #5
Rewards Points: 626
Or why so many golf clubs? Why not just one to do it all? Each type of mud has different uses. As mentioned earlier.
Nailbags is offline   Reply With Quote
Old 07-07-2013, 09:12 PM   #6
DIY staff
the variety is intended to confuse people and make taping a mystery----simple as that----
Old 07-08-2013, 02:14 AM   #7
RWolff's Avatar
Rewards Points: 502
It's all made from the same base product- gypsum.
Old 07-08-2013, 08:22 AM   #8
Rewards Points: 119
What is the different uses for light weight, ultra light weight and topping compounds?
From reading on the USG website that all three can be used for top coats and the light weight and ulta light weight can be used for everything.
Old 07-08-2013, 08:25 AM   #9
Rewards Points: 119
I was not listing all the compounds made just the Sheetrock Brand premixed ones that were in my local Menards.
Old 07-08-2013, 08:59 AM   #10
Light weight is comparable to All Purpose except it has less glue or adhesive in it this makes it softer and easier to work and easier to sand. The downside is less glue, softer, makes it more prone to cracking. Ultra light weight is pretty new I have used it to skim coat and as a topping. But again the less adhesive makes it weaker. Topping is very thin and has no adhesive so it has no strength. It is very soft and easy to sand so it is only used as a final coat to smooth things out. According to USG website these products are pretty much interchangeable except for the topping. This way you don't have to have buy a bucket of each. personally I would not use the lightweights to say, bed tape in a corner, just because of the likely hood of that area cracking if there is any movement. Hope this answers your question.
Old 07-08-2013, 01:28 PM   #11
RWolff's Avatar
Rewards Points: 502
Marketing, and having 3 products on that valuable store shelf instead of one...
Old 07-12-2013, 11:17 PM   #12
automated tool pro
Rewards Points: 152
you can not use the ultra light weight for taping. and with spraying a knockdown. the mud has a tendency to grab the paper and not wipe down as cleanly as an all purpose. The newer USG ultra light is incredible stuff. Every finisher I know loves the stuff. It spreads like butter with about a cup and a half of water added to the bucket. I recommend it for a skin coat. Two coats for me ,friend, but I'm a pro so good luck.
drywallfinisher is offline   Reply With Quote
Is frozen joint compound acceptable once it has thawed? Deck Drywall & Plaster 11 01-03-2013 12:12 AM
Corners are cracking as joint compound dries hoffmandirt Drywall & Plaster 6 04-24-2012 10:33 PM
dots in joint compound insearch Painting 2 06-01-2011 10:44 PM
Will joint compound stick to Zinsser 1-2-3? Lovegasoline Building & Construction 13 09-28-2009 11:55 AM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 06:50 PM
