Joint Compound - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-07-2011, 10:17 AM   #1
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
Joint compound
I have some big areas to cover, and not a pro, which joint compound is easier to use?
Barry
Barry J is offline   Reply With Quote
Old 12-07-2011, 10:45 AM   #2
Rewards Points: 13,968
What is it your really trying to do and why?
Old 12-07-2011, 12:30 PM   #3
Gymschu's Avatar
Rewards Points: 932
Easier in what way? Applying it or sanding it? Are you finishing joints or skim coating? WHat you are doing makes a difference.
Old 12-12-2011, 11:47 AM   #4
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
Skim coating the bad spots. I already treated it with Garz wallpaper repair. And then skim coating the spots
dots in joint compound insearch Painting 2 06-01-2011 09:44 PM
What To Prime Wood With to Accept Joint Compound? Lovegasoline Building & Construction 19 11-03-2009 05:04 AM
Will joint compound stick to Zinsser 1-2-3? Lovegasoline Building & Construction 13 09-28-2009 10:55 AM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 05:50 PM
Hairline crack in joint compound elbee Building & Construction 10 12-02-2008 05:57 PM
