Joint Compound - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-28-2011, 02:58 PM   #1
joint compound
I have joint compound that has collected liquid on the top.
Sappy is offline   Reply With Quote
Old 08-28-2011, 05:47 PM   #2
If its in a 5 gal bucket, take a mixer and remix. How long has the mud been stored, has it ever frozen, try to find a date. I had a friend give me a couple buckets of mud and when I opened them I could tell immediately they were worthless, so if the mud is not too old I would try re-mixing it. You can always use it to tape with.
newfie49 is offline   Reply With Quote
Old 08-28-2011, 05:59 PM   #3
Old School
Willie T's Avatar
If it is very discolored or if it smells bad, throw it out. Otherwise, mix it back in as advised above
Willie T
dots in joint compound insearch Painting 2 06-01-2011 09:44 PM
What To Prime Wood With to Accept Joint Compound? Lovegasoline Building & Construction 19 11-03-2009 05:04 AM
Will joint compound stick to Zinsser 1-2-3? Lovegasoline Building & Construction 13 09-28-2009 10:55 AM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 05:50 PM
Hairline crack in joint compound elbee Building & Construction 10 12-02-2008 05:57 PM
