Joining HardiBacker Backerboard To Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-26-2009, 09:23 AM   #1
Homeowner handyman
Joining HardiBacker Backerboard to Drywall
Hello, I too have joined the ranks and am currently remodeling my bathroom. I am using 1/2" Hardibacker on the walls of my surround for the tub/shower after which I will tile. For now, I have read several threads on how to handle the seams on the Hardibacker and they all make sense. However, I have not seen anything on how the Hardibacker should be joined to drywall, in particular to the ceiling. At this joint, where backerboard meets Dryall, do I use the same Fiber tape and thinset mortar seaming method as if the seam were a Hardi meeting Hardi? Advice would be appreciated!
HanDIY is offline   Reply With Quote
Old 07-26-2009, 10:26 AM   #2
Using the same tape, thinset on the Hardi, drywall compound on the drywall. Thinset can be used on the drywall where they both meet if the thinset will be covered by the tile. Compound can also be used on the Hardi (to some extent) if it is outside the shower area. If you did not use a vapor barrier before the Hardi went on, then i would suggest a waterproofing such as Redgard.
Mop in Hand is offline   Reply With Quote
drywall , hardibacker , remodeling , seams , tub surround
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
bakerboard and drywall ontheroad1015 Drywall & Plaster 3 02-11-2009 06:17 AM
Joining drywall and plaster pete1972 General DIY Discussions 5 10-28-2006 05:08 PM
